New convert under way
+48
superman22x
turbobob924
RestomodCorvettes
chrenan
iamgod
944_GASM
Hotrodz of Dallas
racertomtom
sparkydog
matt889
HorizonblueDK
crowstyle
pa951
ScottM1A
Slpr948
erioshi
blown 9442
Robb Northrup
Gutterboy
bluejk09
cjbcpa
eclou
kelleysj
Insulator
skywalker01
applebit
MillsMotorsport
suboptimalfit
a951
Dan J
laptop_geek
singleslammer
52 posters
Page 18 of 31
Page 18 of 31 • 1 ... 10 ... 17, 18, 19 ... 24 ... 31
Trans mounts
kevin924kevin- Posts : 927
trans mount
Trans mount
Trans mount
Trans mount
Well this is how I will hang the Z06 trans. I was not happy with the look, very functional but not nice to look at. So I made some changes, which I will post pics of once they are complete. I think the changed units look much better but thats just me.
Brakes
Another piece of the puzzle arrived today. My new hydro boost unit showed up.
Trans mounts
Trans mounts ready for welding.
Trans mounts
Plates to mount the trans mount cross member. I have made the plates so they tie in the rear shock
mounts.
mounts.
trans mount plates
trans mount plates
I tried to make them fit as close as you can. The cross member will be welded to the plates and the trans will hang off of it with the new mounts. They should be ready today, they where setting up the laser unit to cut them yesterday.
Re: New convert under way
I'm really enjoying watching your progress! Just in case you haven't encountered this yet I wanted to warn you that when you start welding your various plates onto the sides of the 944's frame rails - the rails can be made of 2 or more layers of sheet metal and if you are using a MIG the outer layer of metal likes to pop/explode as you first apply an arc. I have photos of cuts I made into the frame rails just ahead of the upper shock mount area in case you want an idea of what the interior is like. The outer layer is a somewhat thinner skin and then there is thicker structural metal beneath it.
sparkydog- Posts : 96
Sparkydog please put the pics up. I would like to see the cross section so I know what is going to take place. Thank you for the heads up. Much appreciated.
Here is a shot of a slice directly through the upper shock mount bushings. This would be as if you were looking down onto the tops of the frame rails. The little stubby wings are the start of the upper shock mount "cups". But they are swapped left/right so the inboard surfaces are on the outsides.
At least in this general section of the frame rails, Porsche had more of a C channel shape as the main structural component and then wrapped it up into a bigger, rectangular shape with thinner metal and then further layered the shock mount cup and the rear seatback bulkhead over the top of the tube.
It took me awhile and some swearing to to develop the ability to get a good weld bead into the deeper, stronger metal.
For more details you can go here
and start at post 231. A few posts later there are a couple of shots from beneath looking up into the frame rail.
Thank you for the pic and info
Agreed! I had no idea the frame rails were made like that.kevin924kevin wrote:Thank you for the pic and info
racertomtom- Posts : 144
So what technique did you use to make a good full penetration weld into the outer and inner sheet metal?
Just a good clean surface, crank the heat (within reason)... and proper feed/move speed? Of course talking about MIG.
I was brainstorming, and you could probably take a cut off blade, and carefully slit through the first layer... then lay a bead into that channel, connecting the inner and outer layers, then grind it down and weld ontop of that. Even something more simplified like drilling small holes in the area youre planning on welding, and then filling that hole with weld... thus connecting the inner and outer pieces prior to laying big beads or stitch welds.
Slpr948- Posts : 55
Yeah the "technique" that I used was just to learn that I was going to get burned a lot by hot molten balls of metal blowing out and to just hang in there with feeding wire into the blast zone until it burned off the plating and then the bead would form properly. However it was frustrating because as you say the outer layer just gets burned through and you have to try and sneak the weld puddle over near it and let it wick.
The only other way is what you propose - cut into the outer skin to expose the heavier inner layer (and at the same time clean off the metal to get a good arc).
I believe what is happening is there is hot gas trapped between the outer and inner layer and it's got nowhere to go except back out into your face. So even after making a 1st pass bead if you go back and try to add a 2nd pass the instant you start welding into virgin outer layer you start popping hot metal again.
Post #254 on my link 1st picture has a good shot of the layers of metal in that portion of the frame. And post #261 last two pictures the arc around the tops of the little cup things are my best beads where I had one side new metal and the other side the 944's layered metal.
[You must be registered and logged in to see this image.] 930 CV adapter mounted[You must be registered and logged in to see this image.] 944 S2 axle stub that had ABS/ Machined down to accept 930 Adapter. I used my CV bolts i had and chased the thread all the way down, then cut. Worked out nice.
Trans mounts
Trans mounts
trans mount mock up
trans mount mock up
Trans mounts
Trans mounts
trans mount.
trans mount.
I also worked on my HB unit. Cut the clevis off and threaded for my factory Porsche one. Worked out perfect. I will post that pic. I am still on the fence about the angle it needs to sit at. Do we need to modify the breather port on the drivers side valve cover, for more clearance for the HB unit?
HB unit all ready
HB unit all ready
» Do or Don't convert with L83 motor?
» Convert 1986 to 1987+ Offset
» Convert 944 LT1 Swap to LS Swap
Page 18 of 31
