» WTB 951 or S2 Trans
New convert under way  - Page 16 EmptyYesterday at 4:13 pm by Rikstone
» LS Overheating Issue
New convert under way  - Page 16 EmptyThu Jun 10, 2021 11:24 pm by zeusrotty
New convert under way  - Page 16 EmptyWed Jun 09, 2021 3:00 am by spence
» ECU Wiring
New convert under way  - Page 16 EmptyFri Jun 04, 2021 12:56 pm by Hotrodz of Dallas
» TPC Throttle Cable Questions
New convert under way  - Page 16 EmptyFri Jun 04, 2021 12:54 pm by CyCloNe!
» 944 LT1 engine mounts and dash lights
New convert under way  - Page 16 EmptyFri Jun 04, 2021 8:47 am by quarterflash
» Modified Hooker 2312 Headers for sale
New convert under way  - Page 16 EmptyFri Jun 04, 2021 7:29 am by gwistrup
New convert under way  - Page 16 EmptyThu Jun 03, 2021 9:50 pm by Raymond-P
» lm7 944 swap in the uk
New convert under way  - Page 16 EmptyThu Jun 03, 2021 3:18 pm by mistert1996
» Renegade Hybrids Shorty Headers-Are they any good?
New convert under way  - Page 16 EmptyThu Jun 03, 2021 12:22 pm by gwistrup
June 2021
78910111213
14151617181920
21222324252627
282930
Page 16 of 31 Previous  1 ... 9 ... 15, 16, 17 ... 23 ... 31  Next
New convert under way  - Page 16 Empty Re: New convert under way
Post  xschop Tue Feb 09, 2016 4:09 am
The time spent is well worth it when you can say you own/drive one of the baddest 9's on the planet.
Kevin, did that 18.5" dimension account for the CV adapter location?
I will be cutting a set of axles soon for another 928 Z06 trans swap and I can trim a set of those if I have to as they are about 19"
New convert under way  - Page 16 Empty axles
Post  kevin924kevin Tue Feb 09, 2016 6:53 pm
Rob I will have the unit back in the car next week and will confirm length. Much appreciated.
New convert under way  - Page 16 Empty hours
Post  kevin924kevin Tue Feb 09, 2016 6:57 pm
As far as hours go to many. But the r and d takes a lot of time.when I am done I figure with all parts and supplies needed and working on it 8 hours a day you could do this swap in a couple of weeks or less.best guess on hours would be 300 plus.
Post  HorizonblueDK Wed Feb 10, 2016 12:28 am
Yes, the R&D process takes a lot of time. Bolt on and go projects are much easier. I don't know how much time I spent on my straight six project, didn't keep track of time. But nothing was bolt on and go on that project. Well, the engine could be bolted directly to the bell housing, but apart from that, every bit had to be special fabricated.
I'm working on a 25 foot boat, which I'm restoring from A-Z and making changes here and there. That project started 10 years ago. Until now I have spent more than 3300 hours on that (write down every day how much work has been done). When I started that project, I never expected it to be that comprehensive. But well, projects takes time......
HorizonblueDK
New convert under way  - Page 16 Empty Torsion Tube
Post  kevin924kevin Thu Feb 11, 2016 10:22 am
Step one of my torsion tube is done. I will post some pics on Friday.
Post  kevin924kevin Thu Feb 11, 2016 4:09 pm
Post  kevin924kevin Thu Feb 11, 2016 4:14 pm
Post  kevin924kevin Thu Feb 11, 2016 4:16 pm
Well this is step one. Now to remove the middle section and plate.
Post  kevin924kevin Fri Feb 12, 2016 7:17 am
Post  kevin924kevin Fri Feb 12, 2016 7:18 am
Post  kevin924kevin Fri Feb 12, 2016 7:19 am
Post  kevin924kevin Fri Feb 12, 2016 7:20 am
Post  kevin924kevin Fri Feb 12, 2016 7:21 am
Well here is my rendition of what is needed. Everything fits like a glove.
Next is couple the motor to it and fab the trans mount. You can see in the pic that the trans will hang off that tube, it will be just a few inches towards the TT. I am very happy with the fitment.
New convert under way  - Page 16 Empty Trans
Post  kevin924kevin Fri Feb 12, 2016 4:21 pm
Post  kevin924kevin Fri Feb 12, 2016 4:22 pm
Post  kevin924kevin Fri Feb 12, 2016 4:23 pm
Post  matt889 Fri Feb 12, 2016 5:12 pm
that is some art work there ! props !
matt889
New convert under way  - Page 16 Empty trans
Post  kevin924kevin Sat Feb 13, 2016 2:34 pm
Thank you. Well had a good day on the car. Motor and Trans together for the first time in the car. The drive line fits so nice. I have it sitting with in a hair in all directions. Dropped the gas tank in and no clearance issue there. The only issues I see are one cross member under the hood and I need to adjust where the shifter sits. I took a ton of pics and will post next week.
New convert under way  - Page 16 Empty Motor
Post  kevin924kevin Tue Feb 16, 2016 8:21 am
Post  kevin924kevin Tue Feb 16, 2016 8:22 am
Post  kevin924kevin Tue Feb 16, 2016 8:24 am
Post  kevin924kevin Tue Feb 16, 2016 8:25 am
Post  kevin924kevin Tue Feb 16, 2016 8:26 am
Post  kevin924kevin Tue Feb 16, 2016 8:27 am
Post  kevin924kevin Tue Feb 16, 2016 8:28 am
