» Hard to get good idle
New convert under way  - Page 15 EmptyYesterday at 5:49 am by murrayg
» My Gen 5 LT1 Build
New convert under way  - Page 15 EmptyTue Jul 07, 2020 6:41 am by superman22x
» 1987 951 w/ LS1 for sale
New convert under way  - Page 15 EmptyMon Jul 06, 2020 10:44 am by rdanford
» haven't done a v8 swap in a few years now
New convert under way  - Page 15 EmptyMon Jul 06, 2020 8:58 am by 962porsche
» ls2 automatic, what flywheel should I buy
New convert under way  - Page 15 EmptySun Jul 05, 2020 4:26 pm by mdan1
» Actual weight of 2.5 and 5.7 engine
New convert under way  - Page 15 EmptySun Jul 05, 2020 8:26 am by alex456gt
» Do or Don't convert with L83 motor?
New convert under way  - Page 15 EmptySat Jul 04, 2020 9:57 pm by alex456gt
» Various 944 LS Swap Parts For Sale!
New convert under way  - Page 15 EmptySat Jul 04, 2020 8:52 pm by alex456gt
» FS: 1985.5 Porsche 944 in Michigan
New convert under way  - Page 15 EmptyFri Jul 03, 2020 4:30 pm by tspangle88
» Totalled 1985.5 Porsche 944
New convert under way  - Page 15 EmptyWed Jul 01, 2020 6:09 pm by superman22x
July 2020
6789101112
13141516171819
20212223242526
2728293031
Page 15 of 31 Previous  1 ... 9 ... 14, 15, 16 ... 23 ... 31  Next
New convert under way  - Page 15 Empty torsion tube
Post  kevin924kevin on Mon Feb 01, 2016 10:46 am
Post  kevin924kevin on Mon Feb 01, 2016 10:47 am
[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]0160112.jpg" />
Post  kevin924kevin on Mon Feb 01, 2016 10:53 am
Post  kevin924kevin on Mon Feb 01, 2016 10:56 am
Post  kevin924kevin on Mon Feb 01, 2016 11:06 am
As you can see by the pics, I have started the process of the torsion tube hoop. I will be adding a tube at 45 degree angle of each side of the hoop down on to the TT. Where the trailing arm mounts that will be cut away as per the lines on the tape. I am going to inset 1/4" plate inside the mount and out on the the end of the TT. There will be a gusset welded to the hoop and carry on out on to the top of the trailing arm mount. This should be plenty strong.
New convert under way  - Page 15 Empty Torsion Tube
Post  kevin924kevin on Wed Feb 03, 2016 9:12 am
New convert under way  - Page 15 Empty Torsion tube
Post  kevin924kevin on Wed Feb 03, 2016 9:13 am
Post  kevin924kevin on Wed Feb 03, 2016 9:14 am
Post  kevin924kevin on Wed Feb 03, 2016 9:16 am
Post  kevin924kevin on Wed Feb 03, 2016 9:17 am
Post  kevin924kevin on Wed Feb 03, 2016 9:32 am
Well progress on the torsion tube is moving along. It's all layed up and tacked. I will pull the unit out tonight to make the welding a lot more simple. Once that is done, it will be time to cut out the center and fab the plates. If all goes well it should be completed by mid next week. Following that it will be time for final fitment of the other cross member and tack that in, lay up the balance of the cage etc, and weld. once that is done I will set the motor and trans back in to finalize the trans mount.
New convert under way  - Page 15 Empty Re: New convert under way
Post  HorizonblueDK on Mon Feb 08, 2016 12:33 am
Incredible project Shocked
Don't think I have ever seen so much effort being put into a 924! But great to see that after several years, you still keep working Smile
HorizonblueDK
New convert under way  - Page 15 Empty CAR
Post  kevin924kevin on Mon Feb 08, 2016 8:22 am
thank you. I wish my time was better, but raising a family and running a business takes a lot of my time. My goal is to have it sitting on four wheels and running by June.
Post  xschop on Mon Feb 08, 2016 8:23 am
Still one of my favorite builds to watch. Great job Kevin.
The handling should be incredible with the more weight moved rearwards and wider tires.
New convert under way  - Page 15 Empty Car
Post  kevin924kevin on Mon Feb 08, 2016 8:25 am
Thanks Rob, I will be needing your services hopefully soon for the axles.
Post  xschop on Mon Feb 08, 2016 8:41 am
I'm still curious what the actual/ideal length will be once your trans is set. You may get lucky and be able to use the C5 axle shafts. Remember, you can trim them down some.
New convert under way  - Page 15 Empty Axles
Post  kevin924kevin on Mon Feb 08, 2016 11:19 am
Rob, that wont be the case. I have had the C5 axles in place with the trans sitting were it needs to be and they stick out into the bearing area of the trailing arms. Now in saying that I don't no how much they can be shortened. They appear hollow but I am going to check that out.
New convert under way  - Page 15 Empty Throttle pedal
Post  kevin924kevin on Mon Feb 08, 2016 11:21 am
I said I would post a pic of my DBW gas pedal.
New convert under way  - Page 15 Empty axles
Post  kevin924kevin on Mon Feb 08, 2016 1:14 pm
Did some reading today and the C5 axles are solid, so should be able to shorten and have new splines cut in for the 930 CV joint I would think, but I will confirm that hear with my machine shop.
Post  xschop on Mon Feb 08, 2016 2:05 pm
What is your best guesstimate on what the lengths will be end-to-end?
Post  kevin924kevin on Mon Feb 08, 2016 2:07 pm
Rob, I will measure the vette axles and provide a guestimate.
Post  xschop on Mon Feb 08, 2016 3:58 pm
It would be where the Tri-lobe sets normally to the CV adapter
Post  kevin924kevin on Mon Feb 08, 2016 4:00 pm
ok thanks.
Post  kevin924kevin on Mon Feb 08, 2016 7:23 pm
Rob my best guess right now would be 18 1/2" the vetted axle is approx 21 1/2" it sat flush plus or minus to the face of the outside edge of the trailing arm. The depth inward to where the axle will sit is about 3 1/4".
Post  HorizonblueDK on Tue Feb 09, 2016 12:38 am
Do you have any idea on how many hours you have spent on this project?
HorizonblueDK
