» New 944 widebody & aero
Yesterday at 5:56 pm by scryfst
Yesterday at 11:23 am by Murrdog9000
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
New to the forum / OBD port
Post  Seattle948 on Sat Oct 23, 2010 7:34 pm
Hi all,
New to the forum. Lots of great information here. Driving an 86 951 with LT1 for 3yrs now. Conversion done by PO. The harness used by the PO does not have an OBD port. Engine is a 97 so should have been OBD2. Has anyone here added one to their harness after the fact? I would like to do some diagnostics because it is running really rich and I also did a heads/cam swap a year ago and would like to further adjust the mail order tune I am running now. Thanks in advance for any help you can give.
Seattle948
Re: New to the forum / OBD port
Post  Admin on Sat Oct 23, 2010 7:54 pm
Post up what the motor came out of and we can give you the wiring colors and locations to hook the data plug to. The wires are probably still there, I don't know why people do that. Every body needs a data plug.................... Shocked
Post  bluehellfire666 on Mon Oct 25, 2010 10:48 pm
i did this very thing on my 97 motor...i used shbox and lt1swap.com for my wiring diagrams (mostly lt1swap.com) and wired it in...it was a LOT easier than i thought it would be
bluehellfire666
Post  Seattle948 on Fri Nov 12, 2010 9:48 am
Thanks for the suggestions. The shbox site has a wealth of good info. Found the relevant connectors but they were partially cut so plan to splice in near the PCM. Looks like just 4 wires to the port. 12v, ground, and 2 data.
Seattle948
Post  Seattle948 on Tue Dec 07, 2010 4:45 pm
Spliced in the port, bought a cable, and downloaded Datamaster. Shows DTC 43 - knock sensor circuit. Looks like I have an OBD2 sensor (1997 donor engine) but an OBD1 pcm. This incompatibility causes DTC 43 which then pulls lots of timing and richens a/f n an attempt to supress knock without any data - almost a "limp home" mode. I guess that explains why my car felt slow for my mods - and the cat melted. Very convenient since the car turns 25 years old in 3 weeks and will be emissions exempt in WA. Ordered up a new sensor, can't wait to see what I've been missing....
Seattle948
