Today at 3:12 pm by kevin924kevin
» LS6 Batwing Oil Pan
Today at 2:13 pm by Hotrodz of Dallas
» LS3 Exhaust
» JP's LS1 Conversion
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
January 2018
17mm Allen/ hex key
17mm Allen/ hex key
Post  cfgioja on Wed Oct 20, 2010 5:25 pm
Anyone know where to find a descent 17mm allen wrench or hex key socket without breaking the bank? I need it for my trans.
Re: 17mm Allen/ hex key
Post  Bluemach1 on Wed Oct 20, 2010 5:49 pm
Harbor Feight
Bluemach1
Post  944-LT1 on Wed Oct 20, 2010 6:08 pm
2nd that. I have alot of those sets from HF.
17 mm key
Post  fliermike45 on Wed Oct 20, 2010 7:27 pm
Got mine in Sears tool dept.
Post  Vorsche944 on Wed Oct 20, 2010 7:50 pm
I just picked up a full set with the 17 at Harbor Freight on Sunday. Cheap.
Vorsche944
Post  cfgioja on Wed Oct 20, 2010 7:59 pm
kool. I appreciate it. I did some seraching for just an allen wrench but it was some were near 50 dollars. I will look into it.
Post  sbwrench on Thu Oct 21, 2010 7:02 am
Use a bolt with a 17mm head and either weld a nut onto the threads or use a double nut. Doesn't get much cheaper!
sbwrench
Post  cfgioja on Thu Oct 21, 2010 7:05 am
true that could work. I would have to scrape through my bolt pile to see if I have a bolt and two nuts. Thanks man.
