5.3L or not?
5.3L or not?
I have access to a complete engine from a 2000-2006 Suburban. All accessories included for $700. Would this be a good engine to put in a 944? Should I just continue to look for an all aluminum LS-1?
Tehone- Posts : 84
Re: 5.3L or not?
You can probably find something cheaper. I found my LM4 (aluminum block 5.3L) for 500. No accessories or starter, but did come with engine harness, intake, injectors, crank pulley, truck water pump, and a couple of other worthless bits. Most of that gets changed anyway, so you are still looking at a decent amount extra past the original investment. If it's an LM7 or another iron block version you are after, somewhere between 250-500 should easily be possible. GM made like a million of these motors.
Check out the following thread for more incite around the 5.3L and truck based awesomeness:
robstah- Posts : 352
5.3L or not?
Thanks for the link & write up.
I have been looking for the LS-1 complete swaps and they seem to be in the $2000-$3000 range. I like the weight savings of the aluminum blocks but this engine and I assume that it is a cast iron block with aluminum heads. What I thought good about this engine is that I could get the entire set up, engine, all accessories, wire harness, o2 sensors, exhaust manifolds, computer, absolutely everything for $700.
Thought it would be a rather good investment even if I needed to change some of the items to fit into the 944 engine compartment such as the intake to LS-1 intake and find or fabricate mounts for all the accessories and still come out okay on the initial price.
Don't know much about the LS series engines so this is a learning curve and all the input and suggestions are greatly appreciated. Is there anything else I need to think about? __Thanks,
Tehone- Posts : 84
Re: 5.3L or not?
So what car do you want to put this into.
Year, (NA, Turbo, S2,?)
The 5.3 is a good engine, keep looking for the Aluminum one for the weight.
try [You must be registered and logged in to see this link.] to search the US salvage yards for some. I found the posted prices are easily negotiable. Especially today. Don't tell them what you need it for, they all think Porsche owners are made of money.
Re: 5.3L or not?
what state are you in? If you are in California, you can not put a truck enigine in a passenger car.
Re: 5.3L or not?
I have a 1984 944 N/A, automatic. I am changing out the auto at this point and it has been a learning experience but I am down to the transaxle left on the list .....I think. Thanks for the forum invite.
I do not reside in California and thanks for the info I did not know about truck to passenger no-no's. I am in New Mexico.
After reading in 944v8s "Converting the 944 to V8 Power" when using the 5.3L I need to change out to the LS-1 intake. Will I also need to change to the LS-1 fuel rails and injectors as well? I didn't read this in the article but I am not familiar with the difference in intakes. Somewhere I read that the electrical connectors to the fuel injectors are different between the LS-1 and truck injectors. Will I need to get the LS-1 injectors or just use the adapters that I have found to exist?
Tehone- Posts : 84
Re: 5.3L or not?
Check my thread "nailed it" it shows how I used the truck injectors (multec-2) with the LS1 intake by using 1/2" - 3/4" shoulder bolt spacers on an aftermarket fuel rail.
