damned aluminum
+4
subterfuge
Dan J
expuppy
8 posters
damned aluminum
replacing the power rack and got to the last of the 4 fasteners and STRIPPED the damned xmember. My fault, but the fastener FELT like it was not xthreaded. Poll the group- am i better to:
A. Install helicoil and reassemble?
B- Drill through the xmember and fasten with a bolt and nut config?
C- Replace the xmember entirely?
D- tap to the next largest size?
Interested in what yall think.
expuppy- Posts : 56
Re: damned aluminum
Crossmember - you might be able to find another used one for cheap on Craigslist, Pelican or Rennlist. I can see where that can happen...bummer.
Dan.
Dan.
Dan J- Posts : 117
Re: damned aluminum
Helicoil it. It ends up stronger than it was before.
Dawgz83948- Posts : 603
Re: damned aluminum
If you want an X member, there is one on the bottom of my turbo engine. I won't rip you off too badly.
Re: damned aluminum
I'll have one for sale in a few months too.
Re: damned aluminum
I have one stripped too!!! Just happened last week. I'll be helicoiling it; but I wouldnt lose any sleep if I had to tap it to next size or nut-n-bolt it either.
Re: damned aluminum
I got one if you need it....feel free to PM me. Im worry about heli-coil sometimes, when it you do it with cst aliminum. But Im sure many has done it.
aixgelo78- Posts : 182
Re: damned aluminum
A.....and forget about it.
Re: damned aluminum
i went the helicoil route AND put a nut on the end. aerospace industry is getting to me with all of the redundancy, lol.
expuppy- Posts : 56
Re: damned aluminum
Those bolts are rated at 30lbs of torque, no?
robstah- Posts : 352
