» Headers, headers, HEADERS!
» Electric brakes
steering shaft...
Page 2 of 2 Previous  1, 2
Re: steering shaft...
Post  subterfuge on Tue Oct 12, 2010 1:21 pm
Maybe I am missing something, but wouldn't you need a U joint that is half double D and half splined? The new shaft is double D, but the connections to the rack and the wheel are still going to be splined. This is something that has been on my mind for a while, I'd love to have an absolute solution.
subterfuge
Post  subterfuge on Tue Oct 12, 2010 1:22 pm
So, maybe the Ujoint is just tight or binding at the firewall? I had one the was tight that I thought had a full range of motion. After spryaying some lube on it the motion was much greater.
I had the same experience when I installed my manual rack- the u-joints were pretty beat, but with some lube, they loosened considerably. The first drive was very troubling due to the u joints sticking and pulling on the steering, but after the lube, it was fine.
subterfuge
Post  Porch on Tue Oct 12, 2010 2:44 pm
You guys are having way too much fun with shafts in here. Laughing
Post  docwyte on Tue Oct 12, 2010 2:46 pm
U joint on mine failed. Eric had to replace it...
