» Headers, headers, HEADERS!
» Electric brakes
damned aluminum
damned aluminum
Post  expuppy on Fri Oct 08, 2010 4:30 pm
replacing the power rack and got to the last of the 4 fasteners and STRIPPED the damned xmember. My fault, but the fastener FELT like it was not xthreaded. Poll the group- am i better to:
A. Install helicoil and reassemble?
B- Drill through the xmember and fasten with a bolt and nut config?
C- Replace the xmember entirely?
D- tap to the next largest size?
Interested in what yall think.
expuppy
Re: damned aluminum
Post  Dan J on Fri Oct 08, 2010 4:34 pm
Crossmember - you might be able to find another used one for cheap on Craigslist, Pelican or Rennlist. I can see where that can happen...bummer.
Dan.
Dan J
Re: damned aluminum
Post  Dawgz83948 on Fri Oct 08, 2010 4:53 pm
Helicoil it. It ends up stronger than it was before.
Re: damned aluminum
Post  subterfuge on Fri Oct 08, 2010 5:24 pm
If you want an X member, there is one on the bottom of my turbo engine. I won't rip you off too badly. Very Happy
subterfuge
Re: damned aluminum
Post  Dawgz83948 on Fri Oct 08, 2010 5:34 pm
I'll have one for sale in a few months too.
Re: damned aluminum
Post  944-LT1 on Fri Oct 08, 2010 6:35 pm
Laughing
I have one stripped too!!! Just happened last week. I'll be helicoiling it; but I wouldnt lose any sleep if I had to tap it to next size or nut-n-bolt it either. Laughing
Re: damned aluminum
Post  aixgelo78 on Sat Oct 09, 2010 1:38 pm
I got one if you need it....feel free to PM me. Im worry about heli-coil sometimes, when it you do it with cst aliminum. But Im sure many has done it.
aixgelo78
Re: damned aluminum
Post  948 on Sat Oct 09, 2010 9:00 pm
A.....and forget about it.
Re: damned aluminum
Post  expuppy on Sun Oct 10, 2010 3:04 pm
i went the helicoil route AND put a nut on the end. aerospace industry is getting to me with all of the redundancy, lol.
expuppy
Re: damned aluminum
Post  robstah on Wed Oct 13, 2010 8:19 pm
Those bolts are rated at 30lbs of torque, no?
Re: damned aluminum
Post  expuppy on Thu Oct 14, 2010 6:17 pm
yep, torqued to 30
expuppy
Re: damned aluminum
