» ecotec swap
Yesterday at 3:53 pm by Hotrodz of Dallas
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
Throttle Cable
Throttle Cable
Post  Dan J on Thu Sep 23, 2010 12:17 pm
Quick question before ordering a throttle cable from GM:
Is the cable P/N# 12550676 plug-n-play with an LS conversion?
The reason I'm asking is that no local parts houses in Portland seem to carry this cable. I can order from GMParts direct but cannot return the part if it doesn't work. I'm willing to order a custom cable from Summit as mentioned in a different thread, but would prefer to use the GM part as long as it works in the 944 application.
Just looking for confirmation from someone that this part indeed works with the Porsche throttle pedal connector and LS1 throttle body.
Thank you in advance,
Dan J
Re: Throttle Cable
Post  msmoorenburg on Thu Sep 23, 2010 12:43 pm
Nope you will need to mod it. I used that cable and part of the 944 cable. Its pretty straight fordward when you have it all on the workbench
Thank you
Post  Dan J on Thu Sep 23, 2010 12:52 pm
Hey - thanks for your reply. This is just the info I was looking for.
Dan J
Re: Throttle Cable
Post  Luke714 on Sat Oct 02, 2010 2:37 pm
If this is the cable in the shopping list of the conversion manual I had to cut off one end and insert it through the end that attached to the Porsche pedal and re-crimp. The end that attaches to the GM TB is plug-n-play.
Cable pn 12554852 NLA?
Post  Dan J on Tue Oct 05, 2010 3:10 pm
Hi guys,
I ended up buying the Lokar 36" cable. Called around to all the local parts houses I use (NAPA, Autozone, Baxter), and even a GM dealer parts dept. and nobody could find that Camaro throttle cable The dealer lists it as NLA and not in stock anywhere nationally. Also, had listed that part a few weeks ago when I looked, but the website catalog is no longer available.
So, I decided to use the Lokar 36" cable.
Dan J
Re: Throttle Cable
Post  87-944S on Tue Oct 05, 2010 8:24 pm
Lokar worked for me!
Re: Throttle Cable
Post  robstah on Tue Oct 05, 2010 10:03 pm
Apparently you can still order from there (or I planned on doing so soon) as long as you had the part numbers. You can still plug the same part number in this thread into their site and it will pull up the cable.
Re: Throttle Cable
