March 2019
Hybrid crest: 2 months :(
Page 2 of 2 Previous  1, 2
Re: Hybrid crest: 2 months :(
Post  87-944S on Thu Aug 25, 2011 6:41 pm
I have two of these, was thinking of installing one in the interior as well. May part with the other one.
Polymer coating
Post  fliermike45 on Thu Aug 25, 2011 8:12 pm
I think I'm going to try this:
I just ordered a kit, will report back when I have tried it out.
Last edited by fliermike45 on Thu Aug 25, 2011 8:16 pm; edited 1 time in total (Reason for editing : Added order info)
Post  robstah on Fri Aug 26, 2011 7:07 am
fliermike45 wrote:I think I'm going to try this:
That's what I was originally thinking. The only question is if it will bond correctly. Plastic forming might be able to be done at the house as well. Here's a couple examples:
Hopefully the method can form around the badge to the back, in which it can be trimmed flat and then stays in place based off of the installation of the badge. If it ever goes yellow (and hopefully it won't based on the plastic used), you could always cut it off and reform another piece onto the badge. All I know is that I have no plans of installing this badge as is, especially after what happens to them.
Let's see
Post  fliermike45 on Fri Aug 26, 2011 8:08 am
I will report back as soon as I have tried the polymer method.
Results of the Polytex trial
Post  fliermike45 on Mon Oct 31, 2011 8:15 pm
I finally got around to testing Polytex on my hybrid hood badge.
It's a two part epoxy product that is easy to use. I prepared the badge by covering the rear with masking tape to collect the drips that overflow the edges. I carefully trimmed the tape flush with the edges of the badge. I cut a small wood block to stand the badge on while I applied the Polytex.
Polytex must be mixed in equal proportions and poured over the badge, I had to gently rock the badge to distribute the epoxy. Excess was allowed to drip over the edges. During mixing, air bubbles are generated and will show in/on the poured surface. The instructions suggest you hold the flame of a blowtorch about 8 inches from the surface or exhale your breath on the surface. I did the latter and was amazed to see the bubbles rise and disappear. Something to do with Carbon Dioxide. After the Polytex was poured I covered the whole thing with a clean margarine tub to prevent any dust settling on the surface. Polytex cured overnight and pictures taken.
Pictures show the badge front with the Polytex cured, the rear before I pulled the tape off and the rear of the finished item. I did not have to do any trimming as the tape removal left a clean edge.
PM me if you might be interested in having your badge covered with Polytex.
Post  spence on Tue Nov 01, 2011 4:54 am
Now put it in the hot summer sun for a couple months and get back to us....
Hybrid badge
Post  fliermike45 on Tue Nov 01, 2011 5:47 am
......and if it doesn't work we can all try Spence's solution to this problem.
Post  spence on Tue Nov 01, 2011 6:12 am
I don't have a solution that I know will work.... I'm not about to drill larger holes in my hood only to have to put the stock badge back on.
Simple solution
Post  fliermike45 on Tue Nov 01, 2011 1:40 pm
It's real simple.......I have a spare header panel, if you know what you are doing it can be changed in 20 minutes.
Guess on hot days I will change over to the stock Porsche header panel, and switch back to the hybrid for cold days.
Post  87-944S on Tue Nov 01, 2011 2:54 pm
Just concerned that the site said for indoor use only, I wonder what UV will do to it. Looks great though!
Hybrid crest
Post  fliermike45 on Tue Nov 01, 2011 4:58 pm
Thanks, I'm prepared to give it a try until someone comes up with a better alternative.
Post  the951racer on Sat Sep 08, 2012 4:24 pm
Hey Mike,
You have any updates on your badge? Was just wondering if your coating worked.
the951racer
Badge
Post  fliermike45 on Sun Sep 09, 2012 8:22 am
My car is in storage in FL while I fly a brand new Cirrus SR22T around the Gulf Coast.
Post  the951racer on Sun Sep 09, 2012 2:59 pm
Oh NICE!
the951racer
