Today at 6:55 am by AMFCSL
Today at 1:14 am by sharkey
Yesterday at 9:31 am by Rothaus
Yesterday at 8:55 am by murrayg
» Headers, headers, HEADERS!
» Electric brakes
LS1 stock parts
LS1 stock parts
Post  cfgioja on Mon Sep 20, 2010 4:53 pm
I have a few items listed from the LS1 block I originally started with, if anyone here needs some. This engine had 40k when I bought it and found these parts as I tore down and upgraded.
8 piston rods combo, two pistons are blown though, but the rods and pins are good.
Stock crank
Stock 1.7 rocker arms
rocker arm guide plate
Pushrods
lifters are in the block but I can pull out separate if needed
camshaft and gear with chain
block, needs some machine work from my shops view point. It needs 20+ to clean up the bores. will make a good resleeve or racer block.
this is the worst cylinder on the block, the rest have the crosshatch still, so i figure this was the one with the blown piston.
two oil pumps both in working order
