» NDog52's 1986 NA 5.3 Build - A Summary
hood latch and rad frame/ support mods EmptyToday at 11:30 am by Gutterboy
hood latch and rad frame/ support mods EmptyYesterday at 6:12 am by Colibri Green
hood latch and rad frame/ support mods EmptyTue Mar 26, 2024 3:29 pm by Blaizefed
hood latch and rad frame/ support mods EmptyTue Mar 26, 2024 1:30 pm by Raymond-P
hood latch and rad frame/ support mods EmptyTue Mar 26, 2024 8:49 am by 948
hood latch and rad frame/ support mods EmptyWed Mar 20, 2024 11:52 pm by Raymond-P
hood latch and rad frame/ support mods EmptyWed Mar 20, 2024 1:17 pm by Rob44
hood latch and rad frame/ support mods EmptyTue Mar 12, 2024 3:22 pm by dcoutofstep
hood latch and rad frame/ support mods EmptyTue Mar 12, 2024 2:10 pm by dcoutofstep
hood latch and rad frame/ support mods EmptyTue Mar 12, 2024 12:12 pm by ndog52
+7
Vorsche944
Tetzuoe
Johnny Johnny
turbobob924
11 posters
hood latch and rad frame/ support mods Empty hood latch and rad frame/ support mods
Post  turbobob924 Sat Jun 27, 2009 9:22 pm
OK guys, post some pictures of your hood latch/ pins and front engine bays. in particular those that cut out the stock hood latch area
turbobob924
turbobob924
http://www.turbo924.com
hood latch and rad frame/ support mods Empty Re: hood latch and rad frame/ support mods
Post  Admin Sat Jun 27, 2009 9:34 pm
I am going to make some bolt in hood pins that bolt right in the same place as the pivot points for the headlights. I should have the new headlight conversion buckets ready by the end of the week and then I will start on the hood pins. I am trying to make them all bolt it and sturdy. I have seen some really weak looking pin setups and if I am going to remove the factory latch I want something that is tight....
Post  turbobob924 Sun Jun 28, 2009 12:48 pm
COOL.
So you are cutting out the top plate where the stock hood latch is? This should give another 2 inches for bigger radiator!
turbobob924
turbobob924
Post  Admin Sun Jun 28, 2009 2:30 pm
Yes it does. I will be posting pictures on my web site [You must be registered and logged in to see this link.]
I am installing the motor for Vorsche944 , I picked up his car on Friday and will be doing all the front end mods that he will let me, which will include the pins and my Famous Cool cross member with AC condenser mount.
Post  Johnny Johnny Sun Jun 28, 2009 5:29 pm
I'll be using these:
Johnny Johnny
Post  Tetzuoe Tue Jun 30, 2009 11:34 am
^^those are sweet! might have to consider them as well.
Tetzuoe
Tetzuoe
Post  Johnny Johnny Tue Jun 30, 2009 11:59 am
Check out page 3 in this thread for more info and pics of someone installing these on a fibrglass 944 hood.
Johnny Johnny
Post  Tetzuoe Tue Jun 30, 2009 12:06 pm
Thats pretty impressive work, I dont think Id have any intentions of hiding the latches mostly because I am lazy Laughing
Tetzuoe
Tetzuoe
Post  Johnny Johnny Tue Jun 30, 2009 12:12 pm
Ya, I was kinda thinking the same thing myself (and I believe it's "time conservationist"). I'll probably just use the locking surface mount ones.
Johnny Johnny
hood latch and rad frame/ support mods Empty Seen these?
Post  gt1scca Tue Jun 30, 2009 1:42 pm
I found these earlier...
WMC also offers different styles, non-locking, and black anodized / black chrome versions.
Hotchkis also makes these...
Hotchkis Hood Pins
Post  Admin Tue Jun 30, 2009 3:59 pm
Will you buy me a set? Shocked
Post  gt1scca Tue Jun 30, 2009 7:38 pm
Admin wrote:Will you buy me a set?Shocked
Umm, no. But we can make a set...give me time to find a lock to build around, and the housing should be cake...even on a manual mill.
Razz
Post  Vorsche944 Tue Jun 30, 2009 8:13 pm
we can talk about anything you want to attempt on her. She is sitting in your garage now, so any ideas I will listen too. I do like the idea of a locking hood pin, to many 5 finger idiots out there.
Vorsche944
Vorsche944
hood latch and rad frame/ support mods Empty Theft prevention
Post  xschop Tue Jun 30, 2009 9:52 pm
I have a pit bull 10 ft from the ride and a Glock 40 cal even closer Twisted Evil
It would be nice to have a latch or the original latch moved over and not seen....JAT
hood latch and rad frame/ support mods Empty Closer than that...
Post  gt1scca Tue Jun 30, 2009 10:30 pm
EDITED: Yea, I broke a rule...
2.) There will be no religious, political, handgun or abortion discussions in any forum on this board. I said so.
Last edited by gt1scca on Tue Jun 30, 2009 10:58 pm; edited 1 time in total (Reason for editing : Rule #2)
hood latch and rad frame/ support mods Empty hood pins
Post  damian Fri Jul 17, 2009 11:16 pm
here's some picts of my hood pins:
damian
http://www.integrityfirstauto.com
Post  v2rocket Sun Nov 22, 2009 7:16 pm
im curious if anyone has any experience using this crossmember
any risks with losing crash protection with this in place?
v2rocket
Post  Admin Sun Nov 22, 2009 7:48 pm
I make and sell that cross member. I have sold quite a few in fact. as far as crash protection, I think that it has more strength than the flimsy sheet metal that you have to remove to install it. It is made from heavy gauge steel and fully welded, unlike the factory sheet metal. The cross tube is schedule 40 pipe. much thicker than the 20 gauge sheet metal.
Post  Vorsche944 Sun Nov 22, 2009 9:21 pm
Let me second Eric on the cross member. When you set the sheet metal side by side with the Pipe unit, the strength and integrity are obvious. The cross member supports lateral pull, but the new design also allows fro greater air flow, allows more room upfront for a larger radiator, something the V8 relishes.
As far as my hood pins, we need to post a few picks of the finished product and how it helps out the radiator relocation strategy.
I have both the new cross member and the hood pins along with a relocated radiator, which allowed me to use the summit radiator. (not yet Texas summer tested, but we have high hopes)
Part Number: SUM-380645
Radiator Style: Crossflow
Overall Width (in): 23.875 in.
Overall Height (in): 16.000 in.
Overall Thickness (in): 1.750 in.
Row Quantity: Single-row
Radiator Finish: Natural
Radiator Material: Aluminum
Transmission Cooler: No
Inlet Location: Upper driver side
Inlet Size: 1 3/4 in.
Outlet Location: Lower passenger side
Outlet Size: 1 3/4 in.
Core Height (in): 16.000 in.
Core Width (in): 20.750 in.
Vorsche944
Vorsche944
Post  ghostcloak Tue Nov 24, 2009 11:30 am
I will post up my hood pin setup later tonight. I used the Aerocatch Latches, which if you are interested in send me a pm and I can provide more info. I am pleased with the result. Pics to follow...
ghostcloak
ghostcloak
Post  Porch Tue Nov 24, 2009 1:04 pm
damian wrote:here's some picts of my hood pins:
Hey, nice work!
I like the brackets you made for the pins too. Did you just bolt them to the frame?
Any pictures of your intake setup?
Post  ghostcloak Tue Nov 24, 2009 3:08 pm
Last edited by ghostcloak on Tue Nov 24, 2009 3:11 pm; edited 1 time in total (Reason for editing : .)
ghostcloak
ghostcloak
Post  ghostcloak Tue Nov 24, 2009 3:09 pm
ghostcloak wrote:Haha, I totally didn't catch those pictures. Razz I just welded two plates to the frame rails. I'll have to upload those pictures later, as I don't believe they are avail. online.
Here's a sneak peak though Smile
Works great btw.
ghostcloak
ghostcloak
Post  ghostcloak Thu Nov 26, 2009 5:48 pm
Sorry it took me a while. Better late than never right? Laughing
Driver's Side:
Passenger's Side:
Last edited by ghostcloak on Thu Nov 26, 2009 5:50 pm; edited 1 time in total (Reason for editing : .)
ghostcloak
ghostcloak
