cooling fans
+8
Bridar
modenas
Wild Bill
Luke714
12 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: cooling fans
Mark,
Since your going to have to fabricate custom AC lines anyway, why would you not go ahead and install the port for the GM AC Pressure sensor? Once you have the GM sensor, it is very easy to run the AC control through the PCM so that you have automatic idle up when the AC turns on. I don't know for certain, but I would also suspect that the PCM can also influence the cooling fan settings when the AC is operating. That is, if you are using the PCM to control the cooling fans.
Bridar- Posts : 52
Re: cooling fans
I agree. Take advantage of GMs tech. Its a fine system.
Re: cooling fans
post up the diagram i'll be building my a/c hoses soon
msmoorenburg- Posts : 75
Page 2 of 2 • 1, 2
» cooling fans always on
» F body Altenator on LS1
» Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
Page 2 of 2
