LT1 TACH.... WHAT RESISTOR?
What resistor do I need to hook up to my tach so it reads correctly?? I know you can buy a convertor but they're expensive...
Thanks!
Thanks!
Re: LT1 TACH.... WHAT RESISTOR?
I looked this up on the old board... This was "Mattewb's" car
Is this the resistor I need? Does anybody know anything about these things?
I used a colour coded chart to look up the resistor value and it looks like the resistance of that resistor is 1000 ohms +/- 10%
Does that sound right?
You sir are a genious! Thank you
