Today at 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Today at 6:16 am by bikerdude
Today at 2:33 am by Flashy2003
» ecotec swap
Today at 12:13 am by sharkey
» The famous Hydroboost issues....
Yesterday at 11:30 pm by C4924S
» Tachometer Issues
Yesterday at 10:22 pm by 948
» 83' Porsche 944 LM7 Build
Yesterday at 7:12 am by Jchard944
Tue Apr 17, 2018 5:44 pm by superman22x
» Hydroboost problems
Tue Apr 17, 2018 1:35 pm by Hotrodz of Dallas
» WTB: 944 Turbo Roller
Mon Apr 16, 2018 12:29 pm by knight76
April 2018
30
Brake Question
Brake Question
Post  strubes42 on Sun Sep 05, 2010 7:55 pm
I have a 1984 944 n/a and I am curious if just upgrading to the wilwood calipers will be sufficient enough to stop the v8? Also if i take this route will i have to do any master cylinder relocations?
strubes42
Re: Brake Question
Post  cfgioja on Sun Sep 05, 2010 9:16 pm
The willwood big brakes are sweet. I ran them on my first conversion car and they worked good for manual brakes.
As far as relocating the master cylinder, you still have to do the cereal bowl delete to make room for the engine. Its not hard at all. Also on an early model it is a little easier to make the brake lines fit the brakes and relocated master.
Re: Brake Question
Post  strubes42 on Sun Sep 05, 2010 10:48 pm
how do you do a cereal bowl delete? and would you get class a or class e pads? also would i have to get new rotors that are bigger if i want to switch from my 15" fuschs to 17" twisted turbos?
strubes42
Re: Brake Question
Post  strubes42 on Sun Sep 05, 2010 10:51 pm
or is there a porsche equivalent to the wilwood package? because i'd still like to be able to flash the porsche labelled calipers
strubes42
Re: Brake Question
Post  Luke714 on Mon Sep 06, 2010 12:10 am
go to 944online and look through their brake section, you might find something. They're expensive though.
Luke714
Re: Brake Question
Post  cfgioja on Mon Sep 06, 2010 1:55 am
rennbay sells them.
they fit the regular rotors, and as far as the delete kit goes, that is part of the conversion package from the various sellers of it, or you can browse 944v8s or texas performance concepts for a firewall plate and switch to a wilwood master cylinder but that requires a little more item swaps. I would just look through those sites as far as the conversion kits and see if they sell the bowl delete separate.
those brakes fit the 15 inch porsche rims I ran. You would not have to upgrade rotors, they are recommended to use on regular rotors too, no crossed drill or slotted rotors due to over heating the rotors and shattering.
The only Porsche equivalent is the turbo caliper setup but that requires spindle and control arm swap.
the wil woods will be sweet, they are black and say willwood.
this is there website.
http://www.rennbay.com/944-big-brake-kit-p-83.html?osCsid=8cbaa860ae6fda6aff158daaf8bed5d6
depending on the driving you are going to be doing is what really depends on the pads you select. The street pads were great, they dont experience brake fad like normal pads. The E and A pads are strictly race pads and depend on the speeds you are going to hit.
Call up rennbay and talk to their tech sales guy, he helped me out alot.
Re: Brake Question
Post  xschop on Mon Sep 06, 2010 10:59 am
I have a set of early spindles and hubs already machined for the Lexus Calipers along with the LS430 caliper adapters. I will let them go cheap if anyone is interested....Just PM
Re: Brake Question
