I need your highway cruising rpm
I'm figuring out my cam so I just need to figure out what you run for rpm on highway. I'll be cruising at about 75-80 mph and I'm wondering what that equates to with the long and short 5th gear. Any input would be awesome.
bp944- Posts : 94
Re: I need your highway cruising rpm
~3000rpms.
I got mine down to 2700 with big tires and the lower (numerically) 5th gear.
How big of tires? That is with the 5th gear that's from the 944 gear box not the 951 box.
bp944- Posts : 94
Early 944 box, yes.
I run 285/35's (~100mm sidewall, stock is ~90mm). They rub just a lil bit...
285-30-18 tires, S2 transmission 80mph = 3600 rpm.
Track gearing, not for cruising. Should kick the crap out of everything on track with this gearing though!
285-30-18 rear tires.........85.5 NA trans (awesome 4 speed box!)
........launches beautifully in 2nd gear
.......3rd & 4th Nasty acceleration
.......5th= 2300 rpm @60mph
