Today at 12:20 pm by superman22x
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Oil Circulation
Oil Circulation
Post  Dan J on Fri Sep 03, 2010 8:38 pm
Hi,
I'm working on an LS1 conversion, using the remote filter and Moroso pan setup.
Question, how is the oil supposed to circulate?
For reference, there's front and rear oil lines coming from the oil pan, and a center (slightly off center) and side in/out fittings on the oil filter mount? I've searched to find the right combination - can someone clarify this?
Thank you,
Dan.
Dan J
Re: Oil Circulation
Post  cfgioja on Fri Sep 03, 2010 8:45 pm
I dont remember off hand which oil pan line is which. What I did was hook up my oil lines at the pan and then drape the lines into their own empty soda bottle and spun the engine enough to see which one had oil come out.
That will be you oil pan out.
Now as far as your filter goes, the one with the hole that goes into the center threads is your return to your engine.
So hook your out line from your engine to the hole on the filter adapter that goes to the outside section of the adapter.
Hook the return line to the other oil pan line.
Sorry I dont have any pictures
Re: Oil Circulation
Post  944-LT1 on Fri Sep 03, 2010 9:28 pm
Thanks guys!
Post  Dan J on Fri Sep 03, 2010 9:44 pm
Excellent - thank you guys.
Front of pan to side of filter housing
Rear of pan to center of filter housing.
Again, many thanks,
Dan.
Dan J
Re: Oil Circulation
