» LS6 Batwing Oil Pan
» LS3 Exhaust
» JP's LS1 Conversion
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
January 2018
Audi 012 Transaxles
Audi 012 Transaxles
Post  xschop on Wed Sep 01, 2010 2:10 pm
The DVZ code Audi 012 transaxles have a 3.7 R&P ....The FEC,GBQ codes are 3.44 ...The DUK coded boxes are 3.55 R&P
Re: Audi 012 Transaxles
Post  Dawgz83948 on Wed Sep 01, 2010 3:05 pm
Dont we have enough vw crap in these cars already? Razz
Post  v8carreragts on Thu Sep 02, 2010 12:43 am
This is the same VW crap that is in the Boxter... lol!
Post  xschop on Thu Sep 02, 2010 3:30 am
944 box stamped VW-Audi symbols Razz
That's not the most surprising. The spindles on these cars are ENGLISH design. All English bearings. I think I hold the title for most manufacturers in one car anyways Razz
That reminds me, I still gotta mod my Honda strut tower brace. Very Happy
Post  Porch on Thu Sep 02, 2010 9:26 am
But the 951 boxes have a 3.375 R&P, they bolt right in, and we know they can handle at least 450-600hp sporadically (there are turbo cars making 600+ to the wheels on rennlist, and they're all running Turbo transaxles).
The boxster gear ratios are:
1st 3.50:1 (just as bad as the 944)
2nd 2.12:1
3rd 1.43:1
4th 1.03:1
5th 0.79:1
Reverse 3.44:1
Final Drive 3.89:1 (3.44 available, i guess?)
So basically you're going to spend __ hours fitting in a transaxle that "might" be stronger (in truth, we don't even know if it's half as strong) that has as its best option a 3.44 R&P and a .79 overdrive....meanwhile, the 951 boxes have a 3.375 R&P and the n/a 5th gives it a .72 o/d. Its gear ratios aren't any better either--it's still got a useless 1st gear, and another huge jump from 2nd to 3rd.
With a 25" tire @ 80mph, that equates to:
Stock 951 box: 2976 rpm
Stock 012 box: 2922 rpm
951 box + n/a 5th: 2613 rpm
So no improvement there.
Some of the boxster (and maybe VW) transaxles appear to have limited slip, but the aftermarket LSD units are just as pricey as for a 951 box. The 012 boxes don't have external cooling that i've seen.
End result -- 012 boxes suck.
Said it before and i'll say it again: if you want something you can beat on endlessly and not have it break, the only option is a Tranzilla Corvette Transaxle. While you're in there, pick up a Vette torque tube and save yourself the trouble of adapting it all--and you're done!
Or just save yourself hundreds of hours of labor and research and slap a 951 box in there (or do what Admin did with a "standard setup" tranny and rear axle). I'm sure you'll have plenty of fun with it before something breaks.
Post  Porch on Thu Sep 02, 2010 9:31 am
P.S.--xschop, for all the time you've spent researching and measuring all these other transaxles, you haven't even managed to break your n/a box! What makes you think the Turbo box isn't going to be strong enough for you?
Post  xschop on Thu Sep 02, 2010 9:43 am
You mean my 4-speed NA box that I have not truly let the hammer down on.
The first gear is good for the drive-thru!
You guys are going to make me revert to my original idea and get the AX15. Very Happy
Question.... If I flip the AX15 up-side down, how whould I go about shifting it?
Flipping it upside down and the torsion tube can stay untouched and still mate to the C5 differential.Very Happy
Post  v8carreragts on Thu Sep 02, 2010 10:05 am
Why would you flip the AX15 up-side down? I would think it would not be esier to make up linkage to use the Porsche shift shaft with the trans upright.
Post  xschop on Thu Sep 02, 2010 11:07 am
If you flip it upside down and mate the C5 differential to it, the axles will be right where they should be below the drive shaft centerline. I need to remeasure the 944 TT to torsion tube distance to confirm. I have a C5 2.79 LSD diff. and it will bolt up to the AX15 4x4 housing with an adapter and shaft extension, then the 944 TT can be modified for the front input.
