Today at 12:30 pm by sharkey
Today at 8:54 am by Rich L.
Yesterday at 5:04 pm by AMFCSL
» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Why not use a camaro transmission?
Post  bp944 on Fri Aug 27, 2010 5:44 pm
I was looking at a friends supra conversion with a ls6 engine. He used the T56 camaro transmission and has his camaro torque tube shortened. He adapted the cut of the torque tube for the stock rear end. This seems to be a simpler solution than adapting it before the transmission. But I'm guessing I'm missing something. Does the 944 need a lot of fabrication for the T56 to fit?
bp944
Re: Why not use a camaro transmission?
Post  Admin on Fri Aug 27, 2010 8:47 pm
I have a T56 going into mine. You might want to look under your car, the transmission is in the rear.
I be leave (I'm not a Toyota expert ) but I think the supra has the tranny in the front and a regular rear end.
With that said, yes you can put on in, but you have to remove everything that is Porsche, in the drive train. I had to graft in a larger fire wall tunnel and installed a Camaro rear end even.
Post  bp944 on Fri Aug 27, 2010 8:54 pm
Ohhh, that means weight ratio is blown to hell. I thought that sounded way to simple.
bp944
Post  Admin on Fri Aug 27, 2010 9:01 pm
Weight ratio is not blown all to HELL, There are just a few more things that you have to rearrange. ANd no it ain't simple Shocked
