Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
+8
laptop_geek
12 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
why not just get a griffin direct replacement for a 951 and turbo fan setup. i did notice if u have a na car u will have to cut and make exteansions for the mounting. rather than trying to fit these other rads and fans in there? seems its easier to keep it simple. ill be doing my mounting of the rad during new years and will post pix.
shokwave30- Posts : 68
You can do whatever you want. I used this rad because the shop that I sold my engine to, took my rad and fans and I never went back to get them. It is also alot cheaper and I wasn't afraid of a little challenge... I have full access to all the fabricating tools I could ever need.... I posted the dimensions of the rad and fans and said I needed to make custom brackets and cut the old brackets out of the car.... To each his own; good luck with your car.
Page 2 of 2 • 1, 2
Page 2 of 2
