» Oil Pan question
Today at 7:39 am by Hotrodz of Dallas
» 83' Porsche 944 LM7 Build
Yesterday at 1:39 pm by Jchard944
» Throttle body question
Yesterday at 12:02 pm by Rothaus
» Posche 924 Audi 4.2 V8 ABZ
Yesterday at 11:25 am by Ralphhh
Yesterday at 10:04 am by kevin924kevin
Sun Feb 18, 2018 8:05 pm by 948
» Magnuson supercharged car?
» WTB: LS powered 968
Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
Page 1 of 2 1, 2  Next
Post  spence on Tue Aug 24, 2010 4:03 pm
Here's the v6 cougar fans on the rad. The fans fit perfectly on the Summit radiator #SUM-380645. The hoses might be a tight squeeze though. We'll see what happens when I go to put the hoses on. There's about an 1/8" between the outlet and the fan housing. The mustang guys say they flow 3400cfm.
Re: Pictures - Summit radiator #SUM-380645 with Mercury cougar V6 fans
Post  xschop on Tue Aug 24, 2010 4:16 pm
What are the depth of those fans?
I dremeled the area around the top inlet hose on the NA fans even and the fan bridge to get more hose clearance. Also are you going to reweld the inlet or remove the hood latch arch? Or tilt forward?
Post  Porch on Tue Aug 24, 2010 5:40 pm
Looks good! Let's see how well it fits in the car though...
Post  spence on Tue Aug 24, 2010 6:29 pm
I haven't looked at how I'm going to mount it yet. Do you have any suggestions? What rad are you using?
The only reason I chose this one is because the manual says it requires minimal modifications to the stock support braces.
Here's a 2d cad drawing of the fans.
Fans
Post  fliermike45 on Thu Jan 13, 2011 8:42 pm
What is at the 7 o'clock position on the left hand fan?
Post  laptop_geek on Thu Jan 13, 2011 9:03 pm
How does the size of that radiator compair to the stock 951 radiator?
laptop_geek
Post  v8carreragts on Thu Jan 13, 2011 10:28 pm
951------19.75" x 14" = 276.5 in sq overall size 23.75" x 14"
380645---20.75" x 15" = 332 in sq overall size 23.875" x 16"
1/8" wider and 2" taller.
V6 Fans
Post  fliermike45 on Fri Jan 14, 2011 8:44 am
Can someone tell me what is at 7 o'clock on the edge by the left fan.
I have a Griffin rad and that's where a pipe exits the tank. Can I remove material from the shroud
in that area?
Post  spence on Fri Jan 14, 2011 8:53 am
I can tell you in the spring although, Im sure that doesnt help you now. Sorry, my car is covered under 8" of snow right now and all wrapped up in a tarp. But from the picutres it looks like it would fit. You'd have to cut out that temperture sensor thing though.
Post  944convert on Fri Jan 14, 2011 11:25 am
fliermike45 wrote:Can someone tell me what is at 7 o'clock on the edge by the left fan.
could it be the Auxiliary Fan Control Unit ?
Its a resistor
Post  944-LT1 on Fri Jan 14, 2011 3:24 pm
The part in question is the Cooling Fan Dropping Resistor for the factory low speed fan controller. It is a 0.4 ohm solid wire resistor that heats up as power is applied to the fans. It is placed in the air stream of the fans simply to cool itself off so it doesn’t burn up.
V6 Fans.
Post  fliermike45 on Fri Jan 14, 2011 5:52 pm
Great info thanks, I won't need the dropper as I plan to wire the fans to ECU and use series'parallel relays to get the low and high speed.
Seems this fan unit is a good price and sized right for the radiators specified in Sloan's manual.
Post  zeusrotty on Fri May 24, 2013 3:20 pm
Spence, how did you end up attaching the fan to the radiator?
zeusrotty
Post  spence on Fri May 24, 2013 5:00 pm
I made some brackets (top and bottom) that hold both the rad and the fan together.
Post  docwyte on Thu Jun 13, 2013 8:51 am
You mount these yet?  How are they working?  I'm debating replacing my current Spal electric fan with these...
Post  xschop on Thu Jun 13, 2013 9:35 am
I used those fans on the 928 LS1 swap....2 thumbs up...flow like crazy
Post  spence on Thu Jun 13, 2013 4:38 pm
docwyte wrote:You mount these yet?  How are they working?  I'm debating replacing my current Spal electric fan with these...
Yep, I've had them running for a year... I'm running them from the ECU with the 3 relay setup.
Post  docwyte on Thu Jun 13, 2013 4:39 pm
Any clearance issues?  Where'd you get em?
Post  spence on Thu Jun 13, 2013 4:48 pm
I went to the junkyard for mine. The fan fits tightly in the old opening. I cut the old brackets along the side of the car off.
Post  zeusrotty on Fri Jun 14, 2013 2:49 pm
I got mine from ebay.  they aren't in yet though. Hopefully it will all be done next week.
zeusrotty
Post  docwyte on Tue Dec 17, 2013 12:59 pm
Having issues getting these fans to fit. I have the RH/RD radiator and these fans appear to be too deep to fit without hitting my water pump pulley, etc, etc.
How are you guys getting these to fit?
Post  zeusrotty on Tue Dec 17, 2013 6:16 pm
I went and bought them and didn't get them to fit either. I ended up with 2 11 or 12 inch very high cfm be cool fans that work really well.
zeusrotty
Post  docwyte on Wed Dec 18, 2013 8:51 am
Hmm. Anyone want a brand new set of Cougar fans? $68 shipped!
cougar fans
Post  Tehone on Wed Dec 18, 2013 2:10 pm
[quote="spence"]Here's the v6 cougar fans on the rad. The fans fit perfectly on the Summit radiator #SUM-380645. The hoses might be a tight squeeze though. We'll see what happens when I go to put the hoses on. There's about an 1/8" between the outlet and the fan housing. The mustang guys say they flow 3400cfm.
Hey Spence,
What year of cougar (v-6) did the fans come off of? I am just getting to this part of my build and was concerned about cooling.
Thanks for the info,
George
Tehone
Post  spence on Wed Dec 18, 2013 4:01 pm
95-2000 v6 mercury cougar / mystique or ford contour.
