Looking at a 944...
Looking at a 944...
I'm looking at buying an 86 944 NA locally that has a bad differential gear on its' automatic transmission. How hard would it be to buy the 944S LSD and swap it in?
Or would it be better to just wait and find a 5 speed?
Outofhand- Posts : 20
Re: Looking at a 944...
You will need: Torquetube, shift linkage, shifter, rubber boot, leather boot, pedal's.
Dawgz83948- Posts : 603
thats the fun stuff.
I was curious if the pedals come as a set or do you have to install each seperate? On some ricers they are a whole group assembly you can just bolt on and cut the hole if they already dont have a pop out there.
I found a running 944 for not much more. Might go after that instead... Just got put up on CL by a dealership.
I've been looking at 944s locally for the last 2 weeks or so lol. I don't have a way to tow it around so I'm mostly looking for running or close enough to running it could be fixed easily.
where are you located?
944 and 968 roller s for sale
Hello ,
The pedals are individual they actually slide in , pretty easy swap from auto to 5 or 6 speed. I do have an 1987 944 na auto for sale as well as a 1992 968 for sale , 944 is [$] the 968 [$] obo, some of the pick are photo bucket
Last edited by 944-LT1 on Mon Aug 16, 2010 7:26 pm; edited 1 time in total (Reason for editing : Please use PM'ing for prices)
dp951- Posts : 5
