» Transaxle rebuild
» Tpc LS adapter plate
Oil Pressuer Sender / Relocation Adapter Modification
Post  Bluemach1 on Thu Aug 19, 2010 12:14 pm
Does anyone have a picture of this modification? XSCHOP said he put the sender on the effluent side of the adapter. I am not sure what this means. Is it the input side (from the block) or output side (to the block) from the adapter.
Thanks.
Bluemach1
Re: Oil Pressuer Sender / Relocation Adapter Modification
Post  87-944S on Thu Aug 19, 2010 12:22 pm
Here's a few pics, al ittle blurry, but you can see where it goes.
Post  Bluemach1 on Fri Aug 20, 2010 8:47 am
Thanks for the pix. Still not sure what the "effluent side" means.
Bluemach1
Post  87-944S on Fri Aug 20, 2010 10:06 am
Output side of the mount.
Post  xschop on Fri Aug 20, 2010 10:34 am
The effluent "out flowing" port on oil filters is the center of the filter. My Billet adapter/relocator block came with 2ea 1/8-27 NPT ports (influent/effluent). You should be carefull if you tap that style adapter as it is cast and the side wall where you tap is thin and has large groove threading. You would have to use a 1/8-27 NPT tap and they are tapered. When you screw in the 1/8-27 tapered sender, you can Teflon tape the threads being careful not to crank down excessively because you can stress fracture the thin wall cast alloy there. The other problem is that port that you are tapping into will be constricted by the sender.
I bought this adapter ($45 dabay) and even ported the inner flow channels for even less restriction.....
Post  Bluemach1 on Fri Aug 20, 2010 11:23 am
Thanks Rob. I wasnt familiar with the terms.
Is that adapter billlit? Is it pre-tapped for a sender?
Bluemach1
Post  xschop on Fri Aug 20, 2010 11:54 am
It's anodized billet and pretapped x 2 ports. I'm just running one port for the Oil pressure sender. I got lucky and the braket it comes with mounted right to the driver's side tow hook and sets the filter sideways right behing the deleted foglight which flows fresh air right on it Very Happy
Post  Bluemach1 on Fri Aug 20, 2010 12:14 pm
Good stuff. I was concerned about that cast metal!
Bluemach1
