14 Pin Connector - Check Please
+7
dougs951s
Bluemach1
11 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: 14 Pin Connector - Check Please
Ive "stuck" this topic to the top of "electrical mods" so that people can find it easily and hopefully post additional notes and such.
Since I am running a separate fuel relay for my ecu and my car runs, I can use this pins, correct:
#6- G on oil pressure sender
#9-WK on oil pressure sender
#8- G on temp sender
#10- W on temp sender
That should be everything I need for the stock gauges.
Question, I bought the correct sensor for my lt1 that has the 3/8 npt thread and the same resistance vs temp curve as the stock 944 sensor. I wired the single wire into the blue and yellow wire, pin 8 on the female side of the 14 pin body connector. I still dont have a working temp gauge. I'm not sure what it wrong. Everything else appears to work except that my oil pressure gauge stays pegged, and i believe that is because I am using the stock GM sender which has the wrong resistance; and the PO may have wired it wrong as I just recently inherited the car.
dougs951s- Posts : 32
try grounding out that wire, the temp gauge should move to the top. if it does then you may have too much thread sealer on the sensor, preventing it from grounding. if it doesnt move up you have an issue elsewhere, bad wiring in the car or the gauge just doesnt work.
the stock gm oil pressure sender will be causing the oil gauge problems, you need to run the porsche sender.
sharkey- Posts : 713
Clarification on temperature sensor for gauge
After reading through this thread and looking at the "Manual". It says that one wire is used for the temperature gauge and another is used for the idiot light. The water temperature sensor in the cylinder head has one terminal on it. Are both wires connected to the single terminal on the sensor?
gwistrup- Posts : 111
gwistrup wrote:After reading through this thread and looking at the "Manual". It says that one wire is used for the temperature gauge and another is used for the idiot light. The water temperature sensor in the cylinder head has one terminal on it. Are both wires connected to the single terminal on the sensor?
You need to use the Porsche sensor with 2 pins to make the temp gauge work properly. You can tap the hole in the head for the sensor. There is an adapter made for it, but it pulls the sensor out of the coolant flow, which can cause the gauge to read low. You can also drill and tap a hole in the top of the water pump and install the sensor there.
Temperature sensor
So is the one wire sensor I purchased from TPC that is installed in the rear of the right cylinder head used for the temperature light? Is the two wire Porsche sensor drilled and tapped into the boss on the water pump facing up where the radiator hose points forward? Is there enough room to safely clear the throttle cable? Thank you for the help. Gil
The one wire sensor TPC sells is for the gauge only, not the light. TPC sells that sensor because there is no modification required to fit the LS engine. I have a tap that I use to re-tap the cylinder head for the Porsche sensor. The flat spot on top of the water pump can also be used for the sensor. It clears everything. My personal preference though is in the cylinder head.
Which blue wire for single terminal vdo temp sensor?
Bob or anyone, hoping you can help me close the loop on this thread that came up on the advanced search for where I'm stuck...
For the simple win for temp gauge on single terminal do I need the blue/green wire or blue/yellow wire?
Gutterboy- Posts : 228
Gutterboy wrote:Bob or anyone, hoping you can help me close the loop on this thread that came up on the advanced search for where I'm stuck...
Blue/yellow is gauge. Blue/green is warning light
Gutterboy likes this post
Thanks Bob!
Thanks for replying so quick!
just got all my ecu grounds landed to the back of the block and now i can continue doing these last wiring interconnections to the 14 pin block now that you gave me the answer. I was actually bothering to go through the porsche manual schematics to find the answer myself, man those schematics aren't pretty especially when the pages are split in the pdf.
luckily wasser temp was more discernible as the gauge than whatever the hell HSA means. Couldn't even get an answer through google.
Took some detective work, but I finally got an answer. HSA/KVA is the boost gauge on turbos, or the fuel mpg gauge on non turbos.
Bob Strikes Again
Another mystery solved in the cryptic 944 schematics!
Page 2 of 2 • 1, 2
» 9 pin firewall connector - early cars
» CSR Thermostat Housing Info and Another Alternative
» Help Identify this connector!!!
Page 2 of 2
Today at 9:56 am by ndog52
