Today at 6:52 pm by chrenan
Today at 5:45 pm by AMFCSL
» Tpc LS adapter plate
Today at 5:41 pm by jimbag
» Headers, headers, HEADERS!
» Electric brakes
Steam Pipe routing
Steam Pipe routing
Post  msmoorenburg on Sun Aug 15, 2010 9:15 pm
Anyone run the steam pipe like this?
msmoorenburg
Re: Steam Pipe routing
Post  bluehellfire666 on Mon Aug 30, 2010 10:14 pm
woah that's crazy! i've never seen something like that.
i just bought some pipe fittings with the same diameter and thread pattern. bought one elbow and one tee, then got some high pressure high temp hose and routed it to the stock location on the coolant tank...but that's one heck of a way to do it!
bluehellfire666
Post  spence on Tue Aug 31, 2010 8:59 am
Did you drill & tap the water pump outlet for the steam tube?
Bluehellfire666.... Can you please post pictures of what you did for the steam tube if you have any??
I need to start thinking about the steam tube lines and I have no idea what I'm doing... LOL
Post  msmoorenburg on Tue Aug 31, 2010 9:07 am
I haven't drilled the water pump yet, I found another route. I'll post pics when I get it done this weekend's plan is to finish up the cooling system
msmoorenburg
Post  spence on Tue Aug 31, 2010 9:09 am
Perfect.... thanks!
Post  bluehellfire666 on Tue Aug 31, 2010 11:41 am
there ya go! of course i added hose clamps to it, but this will give you the basic idea
bluehellfire666
Post  spence on Tue Aug 31, 2010 12:05 pm
Oh, I think I already have that tube on the engine. The tube I have is metal... So all I need to do is figure out how to run it into the porsche coolant resorvoir?
Post  bluehellfire666 on Tue Aug 31, 2010 12:08 pm
yup...mine didn't come with a metal tube so i just made my own...if you still have the tube you might be able to figure out how to use it to run it to the porsche coolant reservoir
btw that was my hundredth post! sweet!
bluehellfire666
Post  msmoorenburg on Tue Aug 31, 2010 12:10 pm
My plan is to run it to the small port on the radiator that connects to the radiator cap line.
msmoorenburg
Post  spence on Tue Aug 31, 2010 12:13 pm
What radiatior are you using?
Post  msmoorenburg on Tue Aug 31, 2010 12:14 pm
944 turbo
msmoorenburg
Post  spence on Tue Aug 31, 2010 12:24 pm
I had to buy a new radiator... This is the one I bought (summit 380645)... I know it needs to be modified a bit...
Can someone help me out here?? I think I need to modify / change the following:
1. Cut off rad cap and weld a plate over
2. add a line for the coolant resorvoir
3. add a line for the steam tube??
Post  msmoorenburg on Tue Aug 31, 2010 12:29 pm
If it was me i would run the steampipe to the return line aka first post. After looking my setup over, i think i will run the line to the radiator if that dosen't work i will run it like the first pic
msmoorenburg
Post  spence on Tue Aug 31, 2010 1:56 pm
bluehellfire666... How did you run your coolant lines? How did you incorporate the steam tube and coolant tank?
Post  bluehellfire666 on Tue Aug 31, 2010 5:12 pm
i'm using the stock 944 radiator...want to upgrade to something a bit bigger soon, maybe just a turbo radiator we'll see. i left the main hose that goes from the coolant reservoir to the radiator alone, except i cut and tee'd in the return hose for the heater core. I found two premade rubber coolant hoses that were very close to the dimensions i needed to go from the return on drivers side of radiator to the return snout of the water pump...then found one that was very close to what i needed to go from water pump neck to the bottom radiator snout. There was also a small hose/snout near the drivers side main return line that i capped off, i don't remember what went there originally.
bluehellfire666
Post  spence on Tue Aug 31, 2010 6:11 pm
I'm thinking I can use these tee's to incorporate the steam tube and Porsche coolant tank... Has anyone used these before?
