» SBC conversion without hood scoop
It begins.... - Page 3 EmptyThu May 16, 2019 1:46 pm by sharkey
» ABS brakes won’t bleed
It begins.... - Page 3 EmptyWed May 15, 2019 7:04 pm by knucklehead12
It begins.... - Page 3 EmptySat May 11, 2019 10:55 am by Rich L.
It begins.... - Page 3 EmptyWed May 08, 2019 3:15 pm by lamrith
» Will this throw out bearing work?
It begins.... - Page 3 EmptyWed May 08, 2019 2:48 pm by Admin
» LS Truck engines
It begins.... - Page 3 EmptyWed May 08, 2019 1:42 pm by Admin
» Did anyone do a before and after weight?
It begins.... - Page 3 EmptyWed May 08, 2019 9:12 am by chrenan
» LF: completed kit or mostly complete
It begins.... - Page 3 EmptyMon May 06, 2019 12:36 pm by gamman
» Tuner in Houston
It begins.... - Page 3 EmptyThu May 02, 2019 3:25 pm by JW1970
» k & N filter and intake boot
It begins.... - Page 3 EmptyTue Apr 30, 2019 8:08 pm by JW1970
May 2019
6789101112
13141516171819
20212223242526
2728293031
It begins....
Page 3 of 19 Previous  1, 2, 3, 4 ... 11 ... 19  Next
It begins.... - Page 3 Empty Re: It begins....
Post  xschop on Wed Aug 25, 2010 10:27 am
No apologies needed. All these LS pans are hydroformed/stamped steel from the same damn die somewhere. The various companies just reweld, add on, etc. It has the same ports as the Moroso and every other steel pan. Are those headers 1-off from Eric? Either way you're in good hands there.
Post  docwyte on Thu Aug 26, 2010 5:22 pm
More pics, exhaust is mocked up. Just need to get the X-joint in it, final welding on the exhaust done and pick some exhaust tips...
Post  Arthropraxis on Thu Aug 26, 2010 5:42 pm
Definitely need a sound clip with that is done.
Post  944-LT1 on Thu Aug 26, 2010 5:44 pm
Looks fantastic! What size pipe is that? 2.5?
Post  docwyte on Thu Aug 26, 2010 5:46 pm
Yep, dual 2.5"
Post  Dawgz83948 on Thu Aug 26, 2010 5:49 pm
Just a suggestion, With my dual setup it was a good idea to make the rear length of exhaust removeable (from the torsionbar tube to the tip). Why? Well the stub axles will not come out on the drivers side nor will the tranny drop well. Mine is setup much like yours except the muffler is the Dynomax welded dual 2.5 to single 3". Yours looks like the welded X Dynomax dual in dual out.
Post  docwyte on Thu Aug 26, 2010 5:51 pm
That's a good idea. Muffler is a dual inlet/outlet magnaflow...
Post  cfgioja on Thu Aug 26, 2010 5:54 pm
definitely needs a removable rear end section. My single 3" doesnt have one except for where the headers bolt to the pipe and its a big heavy beast to move around, not to mention having to unhook the 02 sensors.
Post  Admin on Thu Aug 26, 2010 7:25 pm
After the final weld up it'll get cut and 2 band clamps installed right before the torque tube. To much of a PITA to do it while I mock everything in place. Much easier to cut it after the fact. I'll need to do it anyway because we have to install the trans reinforcement plate.
Post  944-LT1 on Thu Aug 26, 2010 7:56 pm
Excellent idea Tim!! I havent got to that part yet but have had to drop the exhaust to get to the tranny with the LT.....never thought of that though. Guru point!
Post  Porch on Fri Aug 27, 2010 3:29 pm
I was going to put a removable section on my exhaust, but it's so easy to drop the whole exhaust that there isn't much point! It's definitely worth it on a car where the exhaust goes over the axle, but on these cars it only takes a minute to drop the exhaust..
Post  docwyte on Fri Sep 03, 2010 5:32 pm
Well, the cam, valve springs, pushrods and timing chain arrived today. Finally!
The motor can go into the car permenantly now. Still waiting on the headers to get back from coating/final welding and the oil pan. Both are on their way, I was hoping they'd arrive today so Eric would have everything.
At least with the motor built and in the car the wiring harness can be done, brakes can be done, AC can be done, etc, etc...
Post  948 on Fri Sep 03, 2010 6:29 pm
Which cam?
Post  docwyte on Fri Sep 03, 2010 8:19 pm
Thunder racing 224 cam
Post  cfgioja on Fri Sep 03, 2010 8:39 pm
Im not good with cam #s. What kind of power band and range are you looking at with that one?
I am trying to figure out a cam for my setup.
Post  docwyte on Fri Sep 03, 2010 10:26 pm
1700-6400rpm. This will probably put me around 385-390rwhp.
Post  cfgioja on Fri Sep 03, 2010 10:55 pm
I was thinking of trying to get a 2000-7000 cam or 1800-6800. Mainly for highway driving, it will still be able to drive on regular streets too, just more power for the top end.
Post  docwyte on Wed Sep 08, 2010 4:00 pm
Cam, pushrods, valve springs and timing chain are installed. Motor is ready to be installed permenantly now.
Post  docwyte on Mon Sep 13, 2010 8:04 am
Update! Motor is put together and should be going in the car soon. Pics below! I went with a double roller timing chain while the engine was out too. Oil pan is finally here as well...
Post  Juramalt on Mon Sep 13, 2010 3:26 pm
Looking good. What Manifold/headers are those? Or are they Eric custom??
Juramalt
Post  cfgioja on Mon Sep 13, 2010 4:56 pm
whats a double roller timing chain?
Post  Porch on Mon Sep 13, 2010 7:14 pm
cfgioja - First of all, i really wouldn't spin a v8 up that high, but that's just me. You're just asking to have a rod hanging off the side of the block, and you'll need some really good cylinder heads to boot. Larger displacement engines just don't rev like the little 4-bangers (and they don't have to!).
A double roller timing chain is like two chains side-by-side (even though it's one chain). It decreases the chances of the chain jumping, and has much greater strength than a single roller.
Post  Bluemach1 on Mon Sep 13, 2010 7:37 pm
WOW. The headers look great!
Bluemach1
Post  cfgioja on Mon Sep 13, 2010 8:02 pm
I see what you are saying about the chain now.
As far as the rpm range. I dont plan on running at 7k all the time just have the ability to reach it if needed. I have ls6 intake, ls6 heads with double springs, short lifters for high rpm, hi tech push rods, 1.72 aluminum rockers, forged pistons, h beam rods, and high lift cam.
Post  Marky522 on Mon Sep 13, 2010 9:05 pm
If you make power up to 7K no reason not to spin these motors that high. Guys do it all the time. Only thing to watch out for is early rod bolts.
Keep in mind with the double roller setups, you may have to clearance your front timing cover to get it on. A lot of people feel the double roller is unnecessary as the LS2 timing set is much stronger than the original LS1 setup, guys are using the LS2 set for big power motors without failure.
Mark
Marky522
