» Headers, headers, HEADERS!
» Electric brakes
Accessory belt
Accessory belt
Post  Luke714 on Tue Aug 10, 2010 6:11 am
Hey,
I was looking at the front of my engine wondering how i was going to route the belt. The conversion manual recommends a 53" belt, is this how it's routed?
Three problems:
1. I'll have to replace the thermostat housing to get the belt to pass through there
2. It runs over an idler that is meant to have the flat side of the belt on it instead of the grooved side, can I replace it?
3. I measured 56.5", can the difference of 3.5" be made up in the tensioner and if not how much do I shave off that number for the tensioner?
Luke
Luke714
Re: Accessory belt
Post  944-LT1 on Tue Aug 10, 2010 8:29 am
Re: Accessory belt
Post  Luke714 on Tue Aug 10, 2010 8:33 am
Excellent, so I was on the right track. Did you move the whole tensioner or just change the pulley?
Do you happen to have the pn for the pulley and thermostat housing?
Luke
Luke714
Re: Accessory belt
Post  944-LT1 on Tue Aug 10, 2010 8:55 am
Neither. Im running an electric waterpump. Thats just a picture from LS1tech. But, they move just the pulley.
No PN for the pulley.... just aftermarket universal probably. The T-housing is CSR911LS1.
Serpentine belt
Post  fliermike45 on Sun Aug 28, 2011 4:59 pm
I'm using a LS1 with stock F body accesories and Turn one PS pump.
The belt for this configuration is 79" long.
DAYCO 5060790, Advance auto Parts part #19270574 (Listed as a 2002 Chev Camaro) $26.99
Re: Accessory belt
