» Headers, headers, HEADERS!
» Electric brakes
Another broken axle-help
Page 1 of 2 1, 2  Next
Post  sbwrench on Mon Aug 09, 2010 7:17 am
Ok, this is the third one I've broken. Always outboard passanger side. The first two were stock axles. The last one I had built special with the biggest balls and cages as possible. 10 mph roll in first and bury the throttle. No clutch drops or shock loading. Pretty sticky tires but street tires none the less. 265/30-18 Goodyear F1's.
I have installed xchop's trans mount. It went in fine. No alignment issues. Is there something else I need to be looking at? Oh, I'm making a little under 400hp at the tires. Anybody got a line on better axles or cv's? Thanks. No time to work on it anytime soon but I'm gathering ideas. I'd like to fix it once and for all. It's a turbo box with n.a. fifth gear. Turbo brakes and hubs. Torsen differential.
sbwrench
Re: Another broken axle-help
Post  Admin on Mon Aug 09, 2010 7:42 am
Do some checking , but I think the 930 CV's will bolt in with some minor mods. They are super strong.
Post  xschop on Mon Aug 09, 2010 8:30 am
930 axles are the ones to mod. The 930 CV's have 28 spline shafts, 94mm PCD ..as compared to the smaller diameter axles, 33 spline, 86mm PCD 944 CV's.
The 930 CV's are also wider in the cages by 6mm than the 944 CV's and have a bigger set of ballz..... lol!
Post  sbwrench on Mon Aug 09, 2010 8:54 am
I'm pretty sure that's how my last set was built. I'll pull one out tonight and get it down to the cv shop in town. Unfortunately I'm on the road for the next 4 weekends. I went to put the trans mount in Saturday and it poured rain! Go figure.
sbwrench
Post  xschop on Mon Aug 09, 2010 9:38 am
So you busted a CV or an axle? And are you saying you have the larger Diameter 930 Axles?
There is an adapter puck drawing somewhere that can mount the 930 CV's on the 944 axle flanges. I'm not suer if the 930 axles come in different lengths to be able to simply install in the 944 without lengthening or shortening, but what is good news is the 930 CV's also have a larger articulation degree than the 944 CV's so thicker adapter pucks can be made to swap over if 930 axle/cv combos are shorter than 944 axles.
Post  sbwrench on Mon Aug 09, 2010 10:38 am
I'm breaking the cv's. Not the shaft itself. It just breaks the cage to bits. The guy that built them fit the biggest cage and balls he could for that flange bolt pattern and diameter. It seems the bolt pattern is the determining factor for the size of the cage and balls. Make sense. I could see using an adapter to allow a larger diameter bolt pattern, cage and balls.
I see a pattern though. First I was breaking bolts and I went to ARP's. Now i'm breaking cv joints. If I fix this, will I be looking at transmissions? I figured my street tires would be a good "fusible link". I guess they have more grip then I had anticipated.
sbwrench
Post  xschop on Mon Aug 09, 2010 11:00 am
He didn't use 930 CV's if he used the factory 944 flanges.... as the PCD's are different.
Which CV busted this time (pass/driver) or the other times for that matter?
I will share my 930 CV adapter drawing as I am rethinking the transaxle upgrade.
I also am assuming the Early offset cars like mine have shorter axles than the later cars and are technically stronger, but more difficult to find off the shelf 930 axles to convert. I'm searching.
Post  sbwrench on Mon Aug 09, 2010 11:04 am
Every time it has been passenger side outter. Makes me wonder if there is something else going on. 88 car.88 turbo gearbox. Turbo hubs and turbo rear breaks.
sbwrench
Post  xschop on Mon Aug 09, 2010 11:27 am
very strange as it usually is the drivers side inner CV.
By the way what is the OD of the axle shaft for the later cars?
Post  Admin on Mon Aug 09, 2010 1:16 pm
Hey, if all else fails, just do like I did and install a Camaro rear end in it! Shocked
Post  87-944S on Mon Aug 09, 2010 1:56 pm
Hey Admin, you need a Ford nine inch in there! Talk about bullet proof! Laughing
Did you have to shorten it?
Post  v8carreragts on Thu Aug 12, 2010 3:08 pm
Or you could try this.........
Post  xschop on Mon Aug 16, 2010 4:10 pm
Hey SB, ask your axle builder what CV's he used. I'm curious if he used the VW Bus CV's as they are str0nger with larger balls and cages, but have less degrees of articulation. I wonder if the couple degrees difference would actually matter?
Post  msmoorenburg on Tue Aug 17, 2010 7:21 am
I haven't had luck with ujoints back in my 280z days, they make loud noises when they go Shocked
msmoorenburg
Post  944convert on Sat Aug 28, 2010 3:56 pm
Do you have 33 or 25 spline axles?
The S2 and later 944 turbos had 25 spline shafts (86mm PCD). I’m pretty sure the axle diameter didn’t change so I’m guessing the CV joint itself was improved.
Post  sbwrench on Wed Sep 08, 2010 11:11 am
Just got back into town. I need to pull the broken axle out tonight and see what is what. I've logged a lot of road time this year. My projects are being neglected!!
sbwrench
Post  948 on Wed Sep 08, 2010 11:51 am
Al, I had looked into CV's quite a while back.....
Post  Porch on Wed Sep 08, 2010 2:28 pm
I would check to see what your CV alignment looks like, too. The further from a straight line the axle gets, the more stress you put on everything!
Post  xschop on Wed Sep 08, 2010 2:41 pm
Convert wrote......"""""Do you have 33 or 25 spline axles?
The S2 and later 944 turbos had 25 spline shafts (86mm PCD). I’m pretty sure the axle diameter didn’t change so I’m guessing the CV joint itself was improved."""""
Has anybody mic'd the 944 Turbo CV's balls and cages? And axle diameters?
So far the best bolt-on solution (upgrade) is the VW BUS Type II CV's with 20mm Balls and bigger cages. It would work since 948 posted the 944's axle articulation.
Post  948 on Wed Sep 08, 2010 8:41 pm
About half way into my own investigation on the various CV dimensions a few years back I found this site....Enjoy Cool
Post  948 on Wed Sep 08, 2010 8:44 pm
The only possible snag I see with the Type 2 CV's is a slightly decreased amount "plunge" over the stock units. Tis could be checked by moving the suspension through its full range....
Post  xschop on Wed Sep 08, 2010 8:46 pm
I have the dims to convert our flanges to 930 CV's but I've seen that site and Type II's would be an upgrade to the Early 944 CV's. I still am curious what the cage and ball dimensions are on the 87-up 944 Turbo 25 spline CV's. I'm begining to think that Porsche stole BMW's CV's off the shelf as they are 25 spline pirat
Post  sbwrench on Thu Sep 09, 2010 7:18 am
I have managed to get tomorrow off. I'll pull the axle and see what is what. I can put a caliper on the cv balls and check diameter and get a spline count. What else should I be looking for? I'm pretty sure the local shop here in Daytona Beach built them with the type 2 ball and cage. You'll never break these, he said!
sbwrench
Post  xschop on Thu Sep 09, 2010 7:56 am
Check the Ball Dia. and cage width. also check the CV outer housing width. If there is pitting/galling in the races on the driver's side, then alot of side to side movement under torque is the culprit a.k.a. factory rubber mount letting the tranny shift back and forth over a long period of time. Their statement would be true if the transaxle remains stationary throughout the life of the CV!
Post  Porch on Thu Sep 09, 2010 1:22 pm
He's running your trans mount, xschop
