» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
944 Hybrid Wide Body
Page 2 of 3 Previous  1, 2, 3  Next
wide body
Post  kevin924kevin on Thu Feb 10, 2011 4:27 pm
The wide body you have created looks very factory. Nice job.
Re: 944 Hybrid Wide Body
Post  Admin on Thu Feb 10, 2011 4:37 pm
Thanks, Now if I can just find time to work on it again, Maybe some day it'l get finished. Crying or Very sad
Post  singleslammer on Fri Feb 11, 2011 11:15 am
This looks great man. These are totally on my list of parts for my 944. You know post v8, brakes, interior, wheels.... It may be awhile, ha ha.
singleslammer
Post  Admin on Mon Aug 01, 2011 8:27 pm
I have taken a few hours to work on my own project. There will eventually be two, Shocked Twisted Evil Twisted Evil
Post  xschop on Mon Aug 01, 2011 8:31 pm
2!.....Nut-T & Nas-T
Post  modenas on Mon Aug 01, 2011 11:42 pm
do a ls1 one
modenas
Post  Admin on Tue Aug 02, 2011 7:10 am
WHY?
Post  cfgioja on Tue Aug 02, 2011 7:58 am
sick. Glad to know you have a complete custom car. I am having enough problems just out of the power my ls6 heads are pushing.
Post  eclou on Tue Aug 02, 2011 8:07 am
Eric I dunno how you are going to find the time to finish her considering the downpour of LS1 swap business coming!
eclou
Post  87-944S on Tue Aug 02, 2011 10:34 am
Wow, can't believe you are fitting all that in there! What's your target for HP?
Post  Admin on Tue Aug 02, 2011 12:37 pm
Well you know as Modenas pointed out, it's only an LT1 motor, so I can't expect to much from it. Laughing Laughing Laughing Laughing
I figure I'll go for the 600 to 650 HP mark with low boost for now. The motor is a well built stroked 387ci. Heads have been worked over and it has a healthy cam in it. I'll be running E85 in it as well.
trans
Post  kevin924kevin on Tue Aug 02, 2011 12:53 pm
Admin, what trans are you running?
Post  Admin on Tue Aug 02, 2011 9:17 pm
T56 six speed.
Nice work!
Post  savage944 on Sun Dec 18, 2011 9:36 pm
Looks great,best wide body rear I've seen.Is the LT1 housing still available?
savage944
Post  Admin on Mon Dec 19, 2011 7:35 am
Are you referring to the LT1 installation kit? If so than yes It is available from my website that is listed at the top of the forum front page.
Texas Performance Concepts
Post  the951racer on Sun Jan 29, 2012 4:45 pm
Any updates on the project?
the951racer
Post  RobotMachines on Tue Feb 14, 2012 12:03 am
Wow
RobotMachines
Post  turbobob924 on Fri Mar 23, 2012 7:15 pm
bad ass wicked
turbobob924
http://www.turbo924.com
Update on the build
Post  Admin on Mon Jun 25, 2012 8:01 pm
Well I have had a change in plans. I sold the LT1 to a guy that had to have it, so it's gone. Also the trans is gone as well as the Camaro rear end.......
I've changed everything, Now I've installed the complete rear suspension from a 2002 C5 Corvette as well as the torque tube. I have also order in a 6.0 from a 2006 pickup. It will be getting a cam, push rods and valve springs to help keep everything rotating smoothly. Plans are to use the twin turbos on it. should make a little power! Cool
With the wide body panels the rear end fits under them perfect.
c5
Post  kevin924kevin on Mon Jun 25, 2012 9:41 pm
Admin, very nice install. Is that an auto trans? where did you mount the supports for the vette stock cross member. What are u using to replace the factory croos member that was cut out. I had Hanks Hot rod mandrel bend my cross member, fits like a glove. Nice to see some one else takin on this conversion. Do you think it is easier to use the vette mounts as aposed to converting the porsche running gear.If you could more pics please.
Post  xschop on Mon Jun 25, 2012 10:34 pm
Nice work. What ratio differential?
Post  Lemming on Tue Jun 26, 2012 6:33 am
Love the idea of running the vette suspension. Through a sequential gear box in there and you would be golden affraid
Post  rockthemullet on Tue Jun 26, 2012 12:45 pm
Admin wrote:[You must be registered and logged in to see this image.]
Did the torque tube fit in the tunnel without modification? I know the guy in Canada cut is apart and was widening it on that 78/79...
Very informative picture
rockthemullet
Post  Admin on Tue Jun 26, 2012 8:59 pm
Rob, Rear axle ratio is 273 for now. Going to try to make the Optima battery face off in Hastings, NE.
Top speed type challenge................... Shocked
As far as the cross member, we are going to make it ourselves from 1 1/2" tubing. We are doing it tomorrow, It will be tied into the roll bar/cage.
The tunnel will be widened a little from the shifter hole back. Will post pictures as things get done.
c5
Post  kevin924kevin on Tue Jun 26, 2012 9:20 pm
Admin looks great. Question, Fuel Tank? are the supports tide in to the frame rails and floor.
