» FiTech option
Thu Sep 20, 2018 2:06 pm by sharkey
» Hydroboost? 1/2" Spacers?
Thu Sep 20, 2018 9:16 am by remaxagent33
» Drag set up
Tue Sep 18, 2018 5:47 pm by Ij944
» FS ABS Powerbrake system pressure pumps
Tue Sep 18, 2018 1:09 pm by jpr
Tue Sep 18, 2018 10:43 am by Rothaus
Tue Sep 18, 2018 10:13 am by Ij944
» 82 924 with AUX Audi V8.
Tue Sep 18, 2018 3:17 am by Golten1986
» Clutch Issues - HELP!!!
Mon Sep 17, 2018 11:16 am by chrenan
Mon Sep 17, 2018 10:08 am by chrenan
» Brand new ls3 build
Sun Sep 16, 2018 7:46 pm by Plucky948
September 2018
3456789
10111213141516
17181920212223
24252627282930
New use for old hood hinges!
Page 1 of 2 1, 2  Next
Post  Admin on Thu Aug 05, 2010 8:20 am
I found a new use for old hood hinges. Just bolt them to the front of the hood Shocked Cool
Re: New use for old hood hinges!
Post  cfgioja on Thu Aug 05, 2010 8:45 am
thats wicked
Post  xschop on Thu Aug 05, 2010 8:50 am
And I thought I had a chopping problem......mad skills yo Cool
Post  Porch on Thu Aug 05, 2010 9:00 am
LOL, nice!
For some reason i thought our hood were aluminum? I guess not! Nice job welding, that hood steel is tough!
Post  v2rocket on Thu Aug 05, 2010 12:56 pm
clever, but why move them? to change the latch position for more front clearance?
v2rocket
Post  Admin on Thu Aug 05, 2010 1:15 pm
Just cause I can,
And it give more clearance!
Post  msmoorenburg on Thu Aug 05, 2010 1:26 pm
wanna make me one Shocked
msmoorenburg
Post  Admin on Thu Aug 05, 2010 1:41 pm
You already have them! It just 2 old hood hinges......................
Post  msmoorenburg on Thu Aug 05, 2010 1:43 pm
I may just do that Cool
msmoorenburg
Post  stuart f. wright on Thu Aug 05, 2010 3:01 pm
looks very nice excellent fabrication
stuart f. wright
Post  cfgioja on Thu Aug 05, 2010 7:21 pm
I need a friend that has machine tools and a good welder. I do the wrenching but I dont have all that stuff. Eric, I am going to move in next to you. LOL. Just got to convince my wife Texas is the pace to be.
I'm sure you are already on it, but now you just have to figure out how to make the struts woork for it too.
I went out and double checked my parts car and I never realised the hinge was that big.
Post  Admin on Thu Aug 05, 2010 9:42 pm
struts are in the works. I have it working with the factory struts, but I don't like the way they look. Headed to McMaster Carr ---------------------------> now!
Post  cfgioja on Thu Aug 05, 2010 9:52 pm
is there a way to apply the hood springs to the hinges?
Post  bluehellfire666 on Tue Sep 07, 2010 6:47 pm
so copying you eric....
bluehellfire666
Post  cfgioja on Tue Sep 07, 2010 9:48 pm
dont know if you got my pm, but I like your idea and am going to look at the 90s model corvettes to see the two rod hood brace they use on that car. its pretty simple and works for the whole front end to flip forward.
Post  Admin on Thu Nov 18, 2010 7:59 pm
Just an update on the hood. Foe those that have hood clearance issue this just might be the trick. It's hard to see from the pictures but it has nearly the same slope / design as the Panamera , just a little taller. It gives me about 1 1/2" right at the throttle body. Heck it might even give those LS guy's room for the super charger. I have not decided if I am going to make this a complete one piece or make it separate hood and valance again. What do you think?
[You must be registered and logged in to see this image.][You must be registered and logged in to see this image.]
Post  cfgioja on Thu Nov 18, 2010 11:15 pm
looks nice, I would seriously have to see the finished product for that.
Post  Admin on Fri Nov 19, 2010 7:28 am
ya the pictures just don't do it justice, It's one of things you really have to see in person. Or maybe out side in the daylight and a nice shiny coat of paint and wheels and , and , and ,and Embarassed
Post  Porch on Fri Nov 19, 2010 9:33 am
Looks great!!
Yeah, i'll definitely have to see it with a fresh coat of paint Smile
Post  docwyte on Fri Nov 19, 2010 11:50 am
Mmmmm, supercharger....
Post  944-LT1 on Fri Nov 19, 2010 12:44 pm
Please tell me its a fiberglass bulge grafted to the OE hood and feathered in? I really like how its 968ish in that it continues into the header. Id really be interested in that. My hood (still in factory gelcoat untouched from gtracing) is all fiberglass so it would relatively easy to graft one on. But, fabing the fiberglass hood to continue into the header would be a bit difficult as far as strength I think. But, I'd do it!
That would really help with a straight air intake/cleaner assembly!
Post  Vorsche944 on Sat Nov 20, 2010 10:51 am
Having seen it up close, it is Very nice. The pics do not do it justice, just like the wide body kit, the curves are feathered in and the front has a slight taper inward, hard to tell with the sanding and bondo work going on.
What I like is it is not an eye sore scoop you see on some car, it fits the body lines and has a subtle message. Plus lots of room under there.
My Vote is for a one piece hood and valence, removing the body line presents a clean longer hood visual, very eye catching and modern. IMO
Vorsche944
Post  docwyte on Sat Nov 20, 2010 9:42 pm
I vote for the seperate header, as with my current intake setup I'd have to remove the entire hood to change my air filter...
Post  Bluemach1 on Sat Nov 20, 2010 10:08 pm
But... With a one piece hood, eliminating the header would allow the aircleaner to be placed up front with easy access! Maybe it could even be further modified to have an opening like a vented badge panel (like AIR or Deutsch Nine) to get that extra airflow.
So I am clear, the hood would open in the normal fashion, correct? (lifting up at the front)
BTW, I did buy the Deutsch Nine vented badge panel (as they call it) and it is CRAP.
Bluemach1
Post  docwyte on Sat Nov 20, 2010 10:10 pm
My air cleaner is mounted up front. It's where the factory intercooler is mounted.
