Do all the LS1's come with an electric smog air pump?
+2
6 posters
I was told only the '02's did, but now some other people are saying they all do.
I need to keep the smog air pump for emissions and it's much easier to mount the electric one vs a belt driven one.
If all the LS1's come with an electric pump, then I can widen my search for motors...
Re: Do all the LS1's come with an electric smog air pump?
Is it a must have item? As long as the motor has just what came on it from the factory it should pass your emmision test, Visual and sniffer.
Only in California.
Dawgz83948- Posts : 603
My 04 GTO engine did not come with an electric smog pump
I took my LS1 from a 2000 T/A. It has an electric smog pump and I will be installing it. I am in California and it is required.
My '01 did not have a belt-driven smog pump, so i assume it was electric.
Here in Colorado I need to retain everything that the motor comes with from an emissions stand point. That means the fuel evap needs to work and the smog air pump has to as well.
If all the LS1's came with an electric air pump, we should be all set...
Today at 12:47 am by sharkey
