Yesterday at 10:58 pm by 948
» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
3 birds with on stone
Post  bp944 on Sun Jul 25, 2010 10:09 pm
3 problems, weight, clearance, air intake. Would a FG hood with FG hood scoop solve it all? I could set up a ram air intake for my 102mm intake setup. It would give me a bit of clearance for the intake that's far too big. It would also take down the weight of the hood by almost 30lbs. I'd like to get the car back to 50/50 ratio. Anyone tried something like this? I was thinking this hood scoop should do the trick. I want it to be subtle and not a gaping hole.
bp944
Re: 3 birds with on stone
Post  modenas on Sun Jul 25, 2010 10:39 pm
it might work, but i need one higher, twin turbos!
modenas
Post  bp944 on Sun Jul 25, 2010 10:45 pm
I feel so sorry for you. Twin Turbos...you poor thing. :p
bp944
Post  Porch on Mon Jul 26, 2010 11:35 am
Couple things:
1. Fiberglass hood only takes off about 20lbs
2. No, that scoop won't help. The area that needs clearancing is the first 1' of the hood. The only hood mods i've seen that address the clearance problem are...well, honestly, hideous.
Post  Dawgz83948 on Mon Jul 26, 2010 12:15 pm
50/50 weight distribution sounds a lot cooler than it is. I've driven my car both ways, 50/50 and 53/47. Can't tell much, if any difference. Right now I sit at 50.5/49.5 which is damn close.
Post  xschop on Mon Jul 26, 2010 12:27 pm
I like the added weight up front. Although I don't pinch pounds, I believe I've removed almost as much weight as I've put in with the iron block....No AC, No cruise control, lighter control arms, billet accessory brackets, lightweight battery....It is not as "bucky" as the stock 944 during hard takeoffs
Post  Porch on Mon Jul 26, 2010 2:02 pm
How much power are you trying to get out of the motor?
These are really not a good chassis for making tons of power... I would be careful how much time and money you put into the motor, because you will not get it back out. Even with my (uncorrected, high elevation) ~290rwhp and 285 tires, traction is an issue. Stickier tires will break the axles, and stronger axles with break the transaxle.
If you have a lot of time to spare i would spend it making the chassis perfect, and forget about going wild on the motor.
Post  modenas on Mon Jul 26, 2010 3:51 pm
if anything, do this!!
modenas
Post  Porch on Mon Jul 26, 2010 4:53 pm
^ Man, that's quite a car! I stand corrected, there IS a way to get these cars to hook!
