Need help finding/ measuring dimensions
Does any know where I can find the dimensions on the holes in this bell housing. It's a 2000 GM V6 3800 and the bolt pattern that I need is the one for the transmission. It the t-5 with what I believe is the same as a Ford.
Thanks in advance,
Thanks in advance,
Re: Need help finding/ measuring dimensions
scratch that. I've seen that tranny pattern somewhere. It looks like a flipped T5 pattern
If you are thinking about TT adapter plates for the V6's.....That BH pattern fits many different engines....
Check on Pirate 4x4, if the pattern is posted, it's on there. I got my Ax-15 pattern off there and it's accurate....
