» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
more imagination
more imagination
Post  bp944 on Wed Jul 14, 2010 7:42 am
Has anyone done a dry sump setup? I assume that takes a lot of modification? Due to a scam that I finally worked through the full car project is a no-go. So this summer will be a massive engine build and then next summer I'll start working on the car. I might as well build a pretty kick A$$ engine.
bp944
Re: more imagination
Post  944v8inDFW on Wed Jul 14, 2010 8:48 am
I have done a dry sump both on the LT1 and LS2 in a 944 Chassis. Unless it is a full on race car it don’t make much since on the street. Major problem is finding room for the bits and pieces for the system. In a race car with a gutted interior pretty easy. Street car, its going to be a struggle. There is a factory dry sump for the Corvette's that if you could find all the do dads used that may be a little less impact to the ole pocketbook.
For the sake of conversation you can figure around $4000 to $5000 in a dry sump system. Considering the cheap oil pumps like the Moroso's are in the $1100 range, just the pump, no drive system, no mounts, no plumbing.
Don’t get me wrong a dry sump system defiantly shows some testicular fortitude when building, and definitely has the coolness factor. However unless you are a very contending racer I would think the money could be spent elsewhere in engine upgrades. But by all means if you got the fab skills go for it! Besides fitting a dry sump system in a space restricted platform will always help you invent new curse words!
944v8inDFW
Post  Porch on Wed Jul 14, 2010 9:27 am
If i were going to spend that kind of cash for a dry sump, i think i'd just pick up an LS7 that comes stock with one. $5k dry sump + $3k engine = $8k you could have spent on an LS7 Smile
Post  bp944 on Wed Jul 14, 2010 3:37 pm
5 grand......imagination time is over. That's more than the price of the build for my whole engine....by a LONG shot.
bp944
Post  Porch on Wed Jul 14, 2010 4:38 pm
If you've got a lot of time to kill but not a lot of money, learning to port the cylinder heads would be a good way to get some free horsepower (or lose some, depending on how much you learn!).
