944 > GM LT1 Wiring Modifications
+2
6 posters
This is also in the "How To" section...
The full instructional is in my gallery...944 > LT1 Wiring Mods
gt1scca- Posts : 795
944 > LS Wiring Mods
It's coming...
The file is done, but I am going to mod xschop's harness to verify everything.
Re: 944 > GM LT1 Wiring Modifications
Im also gonna post some diagrams and stuff as a record of what I did/am going to do with my LSX wiring, as well as the links to ls1tech for all the wiring PDFs. (half way through transcribing my notes on the 99 to 99+ computer swap)
Tetzuoe- Posts : 178
Ok Greg I am onto the wiring harness, I looked through your diagrams on it and looks like you did a nice job.
Any tricks beside whats in the write up you might want to share( maybe something you left out? though I think you covered it all).
Also any chance you may know if the 92/ 93ish wiring harnesses are different or are they same. If ya don't know np I will figure it out eventually.
Dave
P.S.
How's the wife and the baby doing oh ya and you too
Dave
P.S.
ffmedic- Posts : 103
Thanks Dave,ffmedic wrote:Ok Greg I am onto the wiring harness, I looked through your diagrams on it and looks like you did a nice job. Any tricks beside whats in the write up you might want to share (maybe something you left out? though I think you covered it all).
Also any chance you may know if the 92/93ish wiring harnesses are different or are they same...
Dave
P.S.
There are a couple of updates, and I'll try to get them posted later today. I am having to retype everything using my graphics software...can't import an Excel file...
Main difference between the '92-'95 and '96-'97 is the addition of the crank position sensor.
Otherwise, wiring is the same. (Even the early LS uses basically the same circuits.)
Tracie and Kyle are keeping me busy...
News on LsX harness mods in a PDF?
matt889- Posts : 214
http://944hybrids.pbworks.com/w/page/1147193/GM%20LS%C2%A0Wiring%C2%A0and%C2%A0ECM%C2%A0Pinouts
http://944hybrids.pbworks.com/w/page/1147183/944%20Pin%20Connections
Noted thanks!
spence wrote:http://944hybrids.pbworks.com/w/page/1147193/GM%20LS%C2%A0Wiring%C2%A0and%C2%A0ECM%C2%A0Pinouts
Today at 12:47 am by sharkey
