» ecotec swap
Yesterday at 7:02 pm by sharkey
Tue Mar 20, 2018 6:33 am by Patb
Mon Mar 19, 2018 6:35 pm by haroldk
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
March 2018
A noob's first questions
Post  cjbcpa on Fri Jul 02, 2010 7:32 am
I have a lead on an LS6 "Long Block" that has already been pulled and is very close to my house. Recently rebuilt before being pulled. Price is $2,500 with a lot of service records available. Since it is a long block, there are a lot of parts missing.
By my estimate, it will need:
Throttle body
Intake manifold
PCM & harness
Accelerator assembly
Did I miss anything?
How expensive and difficult is it to source these remaining parts?
Will I have to stick with the drive by wire set up or can I convert?
Is this a decent price?
Re: A noob's first questions
Post  cfgioja on Fri Jul 02, 2010 9:28 am
its pretty descent for the price. I picked my ls1 up for 2k.
As far as parts I understand you have to get Fbody brackets for the alternator and any other item you will be running.
You can convert to cable throttle, but you have to switch throttle bodies I believe, not for certain but it can be done.
Depending on how you go about the harness it can be a PITA or simple. I bought a stand alone harness from Speartech, others are adapting stock harnesses and intergrating them. I figured mine was worth the money and love the easy hook up.
Theres a place in OKC that is just about Camaro, Firebird and mustang parts too. Finding the parts wont be difficult just have to locate the correct vendors. Used is always good.
Hope this helps.
