» Oil Pan question
» 83' Porsche 944 LM7 Build
» Throttle body question
» Posche 924 Audi 4.2 V8 ABZ
» Magnuson supercharged car?
Porsche 968 6 speed transaxle is it compatible?
Post  kelleysj on Wed Jun 30, 2010 5:44 pm
has anyone ever used the Porsche 968 6 speed transaxle in this conversion with the 944 conversion?
kelleysj
Re: Porsche 968 6 speed transaxle is it compatible?
Post  Dawgz83948 on Wed Jun 30, 2010 5:55 pm
I hear tell the bolt holes dont quite line up on the torque tube. Also there would be no point since the 6sp and 5sp would have almost idential final drive ratios (so no improvement in rpms or top speed thus no mpg improvement either)
Post  cfgioja on Thu Jul 01, 2010 11:09 am
People have run 6spd conversions in their 944s. Its all over the web and I have seen them at Hallett.
When researching the options the 6spd top end is the same as a factory turbo 5spd. So why run a 6spd just to shift gears faster and reach the same speed without an option to increase the top end. Pointless to me.
Post  Admin on Thu Jul 01, 2010 11:20 am
I'm putting a 6 speed in mine! Although it will be a T56 from a 94' Camaro............ Suspect
Post  Dawgz83948 on Thu Jul 01, 2010 11:39 am
The 968 6sp is NOT even close to the same final ratio as the TURBO 5sp. It's close to the N/A 5 speed.
Post  Porch on Thu Jul 01, 2010 11:48 am
Everyone said it's WAY too much shifting. I would forget about it... The tiptronic might be kinda cool though, not sure what the ratios are there.
Post  Dawgz83948 on Thu Jul 01, 2010 12:12 pm
Id like to see the writeup on what it will take to install the T56.
Post  Admin on Thu Jul 01, 2010 6:20 pm
It doesn't take a write up, it takes a plasma torch and a lot of welding. Razz Razz Razz
If you have followed my car at all you would know that I have total removed all the Porsche drive line and replaced it with an LT1 , soon to be T56 and a Camaro rear end set up with a four link system. Everything is now hung and sitting on air bags, even the front has air struts thanks to some loaners from a Nissan Altima! Shocked
