oil pickup interference
Hey,
I'm modifying and installing the Moroso oil-pan and I ran into a problem with the oil pickup. I was just curious how you handled this, I have some ideas but I don't have enough experience to be sure.
There seems to be some interference between the bracket of the pickup and the shield that goes under the crank. You can see what I mean in these pictures.
Luke
Luke
Luke714- Posts : 441
Re: oil pickup interference
put the bracket on then put the nut on top of the bracket and sheild. Thats how it is suppose to be
lol, I know the bracket doesn't just set on top like that. The thin splash pan (I'm not sure what it's called) doesn't have a large enough depression to accept the footprint of the bracket.
So it won't hurt to just put a hole right through the sheetmetal to make clearance? Just don't do it while it's on the engine
Luke
Luke
sorry, I didnt have that problem with the one I am using.
All that sheet metal is for is to keep oil from splashing into the rods and stuff like that, right? If thats the case a little hole or depression shouldn't hurt anything.
Is there not a way to modify the actual bracket to fit the splashe gaurd?
I think there is, and I would like to try that before I do anything to the engine. I'm pretty sure that I can grind the corners off of the bracket to get it to fit down in. But, I think you're right, it won't hurt to make a hole in the guard.
just double check the rod and bearing clearances to that spot on the sheild. They shouldn't be real close but if you cut a hole to insert the bracket farther the clearance might be an issue. I can't say from here.
» Great customer service from TPC, and new pickup tube lock installed
» VSS setup?
» Rod bearing failure. This pickup tube look ok?
» VSS setup?
