Today at 6:48 am by Michael B.
» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
what is this?
what is this?
Post  cfgioja on Wed Jun 23, 2010 11:59 pm
I found a brass looking cylinder on my rear brake line coming out of the master cylinder. does anyone know what this is for? There was not one on the early car.
Re: what is this?
Post  modenas on Thu Jun 24, 2010 12:09 am
mine has it, im a 88 944S, does that help? i just know it an important fitting and it needed to put my stock master back on
modenas
Re: what is this?
Post  948 on Thu Jun 24, 2010 6:44 am
Bias valve.
If you look in your conversion manual there is a section on these.
Re: what is this?
Post  cfgioja on Thu Jun 24, 2010 10:54 am
I didnt even think to look there. Thanks
Re: what is this?
Post  Porch on Thu Jun 24, 2010 2:40 pm
It's a pretty good time to buy a Wilwood manual proportioning valve and stick it inline on the back brakes.
Re: what is this?
Post  cfgioja on Thu Jun 24, 2010 4:32 pm
the manual one you are talking about, would allow me to adjust the rear brakes as needed? I am just swapping into a daily driver car. what is best for a street setup?
Re: what is this?
Post  Porch on Fri Jun 25, 2010 2:20 pm
Yup, you just turn the knob until you have the desired braking pressure! (May require some fine tuning, you want to avoid having your rear brakes lock up)
Just search for "Wilwood proportioning" at your favorite speed parts store (or ebay), they're about $50. Since you already have to re-do the brake lines at the master, they're no extra effort to add in.
Re: what is this?
Post  cfgioja on Fri Jun 25, 2010 7:35 pm
that looks nice. Does the stock proportioning valve not put enough brake pressure at the rear?
Re: what is this?
Post  Porch on Mon Jun 28, 2010 11:31 am
Nah, the stock setup is fine if you're not changing anything on the brake system. I put a Wilwood master cylinder on mine so the adjustable bias is required. It would also be necessary if you change the rear brake calipers.
Re: what is this?
