» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
My passenger side motor mount is not fitting right (pictures)
Page 2 of 2 Previous  1, 2
Re: My passenger side motor mount is not fitting right (pictures)
Post  spence on Fri Jul 02, 2010 4:47 am
To be honest I recommend you go to summitracing.com and buy the poly mounts. They do NOT settle at all.
I really don't think it's going to matter if I use the rubber mounts I have or the poly ones. They're both going to hit.
I was just reading Greg's build post. Sounds like he designed this pan to be used with a manual rack.... Great... I was not aware of that
Post  Dawgz83948 on Fri Jul 02, 2010 9:25 am
The Poly Mounts keep the motor ~1/2" higher than the rubber ones. I had a hard time getting my hood to close after the poly mounts were installed. There is not much give in polyurethane.
Post  spence on Fri Jul 02, 2010 9:59 am
What I mean is when I lowered the engine to bolt the uprights on the oil pan touches the steering rack first and no weight at all was on the uprights. I was reading Greg's post and he mentioned that the manual rack sits flush with the cross member. If this is the case the oil pan would be fine and have enough room to clear the manual rack. I think I need to get a manual rack
Are the poly mounts spaced differently than the rubber ones?
Post  Dawgz83948 on Fri Jul 02, 2010 10:00 am
Ahh, no they are identical to the rubber mounts. The only real difference is they have a shim that goes on the back to preload the poly.
