Today at 6:37 am by Patb
» 5.3 conversion on 88 Turbo
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
» Dry Sump Oil Pan Fitment
May 2018
78910111213
14151617181920
21222324252627
28293031
hotwire a 944
hotwire a 944
Post  bp944 on Sun Jun 20, 2010 12:28 pm
I'm looking at buying a car with a locked starter ignition. Everything works fine on the car other than that. Could I possibly hotwire it and drive it back? Will the steering column still be locked?
bp944
Re: hotwire a 944
Post  modenas on Sun Jun 20, 2010 12:47 pm
yes it will be, take the ignition out and how wire there at the back of the ignition.
modenas
Re: hotwire a 944
Post  944-LT1 on Sun Jun 20, 2010 4:08 pm
The steering cloumn lock is held in place by two irreversible dome head bolts. You would have to first drill a hole into the head of the bolts and then drive a bolt extractor into the hole to free them. Then, the assembly will drop out and away and allow you to get to the connections on the reverse side of the ignition tumbler. Otherwise, you will have to call a mobile locksmith to the scene and have him make a key. Have the title and vin ready to go!
Re: hotwire a 944
