» New 944 widebody & aero
» Oil Pan question
» 83' Porsche 944 LM7 Build
Steering rack drop down
Post  Admin on Sat Jun 20, 2009 12:45 pm
If I made a tubular cross member that clearend the stock oil pan on the V8 I would need to drop the Steering rack down a little also. What could be done at the tie rod end to get the geometry back to the right place? xschop? Anyone?
Re: Steering rack drop down
Post  alienwerke on Sat Jun 20, 2009 1:07 pm
how much would it be required to lower the rack? Shocked bottom out chance? maybe a combination of spacers at tower struts and motor mount uprights??
yes i am the naive dreamer here. confused
alienwerke
tubular Xmember
Post  xschop on Sat Jun 20, 2009 1:09 pm
MMMM....I would maybe want one....
The Ti-rod drop down kit I designed is the ticket I will post up pics in the next day or so.
I dropped my X-member down 1" so far and I maybe do another 3/8. I like the Idea of a lower Center of Gravity that the stock 944 engine Very Happy
PORH Razz Razz
Post  Johnny Johnny on Fri Dec 11, 2009 10:24 am
xschop wrote:MMMM....I would maybe want one....
PORH Razz Razz
With this drop, my steering intermediate shaft is now too short. When I connect it where the column enters through the firewall, it's only off about 1/2" or so, enough that I can't get the pinch bolt in. Should the shaft be lengthened, or should the pinch bolt "groove" be lengthened? Something else I'm not thinking of?
Johnny Johnny
Post  xschop on Fri Dec 11, 2009 10:43 am
Hey Johnny. I lengthened mine by 1.25" because my X-member is dropped 1.25"
I wish I would have measuered the 944 PS shaft before the mod. I believe that an inexpensive alternative could have been found that has more compact U-joints on it that clear the Motor mount area better than the factory u-joints, it's close in there.
Post  944-LT1 on Fri Dec 11, 2009 1:02 pm
Ive been waiting for someone to tackle this! You should design it around the stock 2008 vette pan = low profile and close to the moroso pan. That would be awesome. But im sure you have something better in mind. Would have loved not to have to use a remote oil filter and lines and anything else that has to be done because of the OE x-member.
This would be the greatest thing developed for the 944 v8 conversions since the TT-C5 adapter plate!
Go getem Eric! Very Happy
Post  matthewb on Thu Jan 07, 2010 8:59 am
Xschop.... its matt from over on PHB I have finally come over here... I don't have enough posts yet to send a PM or I would. Can you send me some or post up some info on the final design you came up with for the tie rod drop down kit? I am looking to change a few things around on my car. I have the entire thing all torn back apart for paint and a stroker motor so it seems like a good time for me to make a change like this. I am not sure yet but I may have to add a deeper pan to my engine to make room for my stroker crank. I don't know yet but if I have to then I will definately require some changes i n the cross member and rack.
matthewb
Whu ?
Post  xschop on Thu Jan 07, 2010 9:26 am
I designed 5/8" Bump-steer drop pins out of 4130 steel that require you to Drill and REAM your spindle knuckles to 0.625" (5/8"). It allows you to buy inexpensive 5/8" Heim joints (don't be a cheap ass...TEFLON lined) and Toyota Inner Tie rods for the Power steering rack and VW Rabbit inner rods for the manual racks. 1.00 to 2.125" drop at the knuckle can be obtained with the new 5/8" "toplocker" nuts.
http://944hybrids.forumotion.com/suspension-mods-f6/x-member-drop-down-bolt-on-bump-steer-kit-t20-15.htm?highlight=bump+steer
What the hell took you so long, Funky music kept ya goin' over there..... afro
Post  matthewb on Thu Jan 07, 2010 9:56 am
I will read up on the modification. Thanks.
I haven't been over on that board either actually. I got tired of reading all the arguing. I have checked back a couple of times in the last few months and its a ghost town. I was too busy driving my car to be reading about them but now its back to work.
matthewb
