» ecotec swap
Yesterday at 8:46 pm by sharkey
Tue Mar 20, 2018 6:33 am by Patb
Mon Mar 19, 2018 6:35 pm by haroldk
» New 944 widebody & aero
» Wilwood MC on it's side
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
March 2018
automatic to manual
automatic to manual
Post  bp944 on Sat Jun 19, 2010 4:17 pm
How hard is it to convert a automatic car to manual. I'm already planning on changing the transmission and all, so what are the draw backs?
Re: automatic to manual
Post  Marky522 on Sun Jun 20, 2010 8:00 am
No draw backs, you will just need the pedal assembly from a Manual 944. You would be switching to the after market Clutch Master anyway to work with the GM slave. Besides that, youll need a shifter assembly, shift rod, cant remember if the axles were the same or not, i dont believe they were, if It was me, I would get a set of Auto zone reman axles, that way when you Pop them you have a lifetime warranty.
Post  xschop on Sun Jun 20, 2010 8:18 am
I swapped an auto for a manual before....I would only bother with it again if I were swapping in a V8 Very Happy
It is perfect timing since you have to remove all the auto flywheel/rubber flex plate anyway.
Post  stuart f. wright on Mon Jun 21, 2010 12:33 pm
i have auto equiped 944 converted to a v8 and it works very good.and it launches really hard but it doesnt have the top end mph as an overdriven manual should be able to use a donor 944 transaxle and tourqe tube and bolt it up to yours.the auto trans tourqe tube basicicly the same without the shifter provisions and also the halfshaft axles are different on the auto trans vs manual trans you will need to swap them also
stuart f. wright
Very interested in doing a 968 V8 Automatic
Post  johntorg on Tue Dec 14, 2010 10:03 am
Stuart. I am very interested in building a 968 automatic LS1 or LT1 powered car. Do you have the details of your conversion anywhere?
