» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
bellhouse adapter CNC
Post  bp944 on Sat Jun 19, 2010 2:06 pm
How accurately does the adapter need to be cut? Will +/- .001 in work?
bp944
Re: bellhouse adapter CNC
Post  xschop on Sat Jun 19, 2010 5:00 pm
Better than RH tolerances..... Razz
Post  xschop on Sun Jun 20, 2010 8:14 am
All kidding aside..... 0.001 is pushing it. You may not have trouble inserting the shaft tip in the pilot, but if it is that far off from concentric, you will need extra pilot bearings on hand and possibly a replacement TT shaft as it will suffer from oscillating metal fatigue due to the constant radial load when it is not concentric. Not to mention you may need to hammer on your plate to C5 Bellhousing dowels as they are precision machined in relation to the shaft concentric.....To be safe the dims shouldn't be out 0.0005
RH found this out the hard way.
