Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
will the Sachs strut assembly work with the weltmeister coil overs?
Post  kelleysj on Wed Jun 16, 2010 3:35 pm
will the Sachs strut assembly work with the weltmeister coil overs? And what other options are there?
I have an 88 944 N/A
kelleysj
Re: will the Sachs strut assembly work with the weltmeister coil overs?
Post  89VWdieselGolf on Wed Jun 16, 2010 4:18 pm
sachs is an OEM strut. OEM company's say stock struts are good for maximum of 1.5" lowering... Now that being said, they still wont last as long as stock ride height, they just wont blow in a month like they would if you lowered the car 2"+.
I'd personally go with Koni's... they'll pay for themselves in the long run
89VWdieselGolf
Post  Arthropraxis on Wed Jun 16, 2010 5:54 pm
I went through Paragon and got Koni yellows with the adjustable ride height kit. If you aren't familiar with the ARHK it is a simple procedure to turn your stock sealed struts into coil over shocks using the Koni insert.
Post  xschop on Thu Jun 17, 2010 9:34 am
The Early struts are a cakewalk....build your own...it's not that difficult. I used Black Magic 300lb springs with tophats and lower adjusters.
The late car struts can be modded with the Koni inserts if you don't have fab skills....
Or if you can fab some....
http://944hybrids.forumotion.com/suspension-mods-f6/late-spindles-on-early-struts-t296.htm?highlight=late+struts
Post  m73m95 on Fri Jun 18, 2010 1:29 pm
"The Early struts are a cakewalk....build your own...it's not that difficult. I used Black Magic 300lb springs with tophats and lower adjusters."
Can you explain how you did that? And, where you got the parts?
m73m95
Post  xschop on Fri Jun 18, 2010 3:33 pm
It's over on the $hitlist..... I used Corolla coilover height adjusters/perches (Ebay)and made my own tophats to fit 2.5" 300lb coils from Southwest Speed....
http://www.southwestspeed.com/?sec=view_menu&cat=Suspension&sub=Springs&ssub=Coilover Springs&sssub=2 9/16" Diameter x 10" Tall Springs
The Tophats can be bought for about $60 from various places...The Early struts bottom spring plate doesn't even have to be cut down if you are lazy....
I used KYB II gas adjust struts and double spring set-up on the first set and sold them.....
Then I made another set with the Black Magic 300lb springs for my Iron Block 5.3....
I have a spare set of complete Early 944 struts in case I get bored this winter pirat
Post  kevinlvy on Wed Dec 01, 2010 11:49 pm
i like the DIY parts you can do for your car, also a very nice idea to use the corolla coilcovers. Yeah Koni's are the bang for the buck and also KYB, anyone have tried a monroe parts for this specific area? Cool
kevinlvy
