» ecotec swap
Today at 1:36 am by sharkey
» WTB: 944 Turbo Roller
Yesterday at 9:14 am by rrracing1970
Wed Apr 25, 2018 5:25 pm by rrracing1970
» What is VSS?
Mon Apr 23, 2018 10:53 am by C4924S
» The famous Hydroboost issues....
Mon Apr 23, 2018 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Sun Apr 22, 2018 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
April 2018
30
Newbie needs help
Newbie needs help
Post  bp944 on Sun Jun 13, 2010 9:52 pm
I'm looking to build up a 944 track day/daily driver. I know I'm a little crazy but I want to run this in the winter in Minnesota. That means I need to be able to raise it a good amount. High enough to get over good sized speed bumps and low enough to be a decent track car.
bp944
Re: Newbie needs help
Post  xschop on Sun Jun 13, 2010 10:50 pm
Bag it.
Post  modenas on Sun Jun 13, 2010 11:54 pm
if you want to lower your car and have an ls1, do it to a vette, not a porchevy
modenas
Post  bp944 on Mon Jun 14, 2010 10:45 am
I'm not slamming my car or lowering it. I'm talking about putting track racing coilovers on it. I just can't have it that low or I'll bottom out. Am I totally off the mark or something?
bp944
Post  gt1scca on Mon Jun 14, 2010 10:54 am
Aftermarket coilovers, such as Paragon or Ground Control, are adjustable. You can maintain factory ride height, no problem. You could change your (ride-height) setup and alignment before going to the track, then reset to factory specs after you get back from the track. Camber will require changes after height adjustment, BTW.
Post  bp944 on Mon Jun 14, 2010 11:01 am
What would it take for me to do all that by myself, aligning tires and all? Or is a professional just the way to go?
bp944
Post  gt1scca on Mon Jun 14, 2010 11:06 am
Get the front-end aligned professionally before the track event.
OR, leave the factory alignment in place.
Even for a track day.
With quality coilovers and struts, factory alignment settings will be more than adequate for the occasional track day, unless you're Boris Said...
Razz
