I am embarking on a new journey....
holy crap...i'm losing my mind....just a disclaimer.
Today I pulled my wiring harness, and a buddy and i completely unraveled it...cut all the connectors and labeled where wires went, and plugged the connectors in. We're going to be relocating the engine computer to the passenger compartment (got a b body harness so i had the computer under the header panel) and redoing the entire harness, making it cleaner and considerably more concise. Once everything is laid out, the entire thing will be wrapped in heat shrink to protect it and clean it up.
I also removed the headlight motor and bar, and we looked at how to fix the headlights up until i can build headlight buckets with lexan covers. We pulled the windshield washer fluid reservoir since it leaks...
v8944- Posts : 211
Re: I am embarking on a new journey....
I used mechanic wire on the bottom of the triangle piece that hooks to the back of the headlights and strapped it to the inside of the bumper to keep my lights up after removing the motor and bar. cheap and easy for a simple fix. not perfect though.
good call, i might have to look into something like that! i was thinking about welding (just tacking) a piece of steel between the pivot bar that goes through the headlight and the sheetmetal under the header panel. That seemed too permanent, so i think i'll run a screw through that metal stopper that comes off the back of the headlight into the frame/sheetmetal it stops on...that's more reversible if i decide to go back at some point.
btw, pics with be forthcoming!
v8944- Posts : 211
Really excited to see this! Bold way to be man
adam7e- Posts : 63
alright...spent some time on it today getting things like i want them...
First, i put a couple of self tapping screws through the stop-brackets on the back of the headlights into the sheetmetal in where they hit to secure the headlights in the up position permanently. I had made a run to advance auto with what i wanted to do with the air intake in mind, then with some cutting of rubber and steel, i came up with a new intake setup (see pic). When i took a good look, i decided i was going to try to get the stock hood on...it worked, i just had to notch the hood support by the throttle body a little...but it would even close without doing that. Pretty crazy stuff huh?
v8944- Posts : 211
