Shifter Slop
Shifter Slop
Here is a good write up on how to fix shifter slop
msmoorenburg- Posts : 75
Re: Shifter Slop
Great write-up, thanks! I also like the idea of an aftermarket shift knob.
Re: Shifter Slop
Hey thats real nice! Mine was a crap load worse like a football shape (for fun = prolate spheroid).
Now did you install a bearing/bushing? I here the shift rod is not hardened and could be ruined by the bolt. Just kidding.
Re: Shifter Slop
I did a similar fix, but I used some small 10mm thrust bearings to apply the force to the sides of the shift tube:
turboswede- Posts : 8
Re: Shifter Slop
Whats happening here turboswede? This thread was from 2009. Lets not dredge up very old threads sending new threads down before they've had their time up top. Thanks!
