Today at 7:52 pm by matt889
» New here needing help
Today at 3:45 pm by sharkey
» 5.3 conversion on 88 Turbo
Yesterday at 11:00 am by kevin924kevin
Tue May 22, 2018 10:36 pm by mryan318
» Clutch Issues - HELP!!!
» Hydroboost Lines from TPC
» 1984 Gen IV 5.3 Swap
May 2018
78910111213
14151617181920
21222324252627
28293031
suspension/offset question (late to early change possible)
Post  bluehellfire666 on Sun Apr 25, 2010 6:03 pm
crosspost from ****list, maybe you guys will know
Wondering if anybody over here has any thoughts about changing from late to early offset. I've been looking at a lot of possibilities for ways to fit wide rubber under the fenders, and most of the options are 17/18 inch wheels, which i HATE (for some odd reason). I won't go over 16 inch, so Gotti's and BBS are looking good, but they are ALL early offset (guess they were options on the 930) and my car is late.
What needs to be swapped to make a late offset car an early? Do i need to do spindles/struts/control arms/tie rods/etc etc? or is it possible to do it with less change? like maybe just control arms and tie rods?
Thanks in advance!
Ethan
bluehellfire666
Re: suspension/offset question (late to early change possible)
Post  Admin on Sun Apr 25, 2010 6:21 pm
I am just speaking from my trial and error on the subject.
I think you would need the early A arms of course, early struts and tie rods from the rack out. I assume they would fit the late model power steering rack.
You might need the hub and such also, I am unsure about that.
Post  xschop on Sun Apr 25, 2010 6:38 pm
You'll be doing yourself a disservice by putting back on Early spindles as they have smaller bearings and the bolt-on rotor is an afterbirth design of one of Porsche's brainfarts. Avoid the 86T spindles/hubs like the plague....another transition design
You can slot the Late strut/spindle interface bolt-hole to keep the late hubs/spindles and struts, then get Early control arms and tie -rods....Hint, If you are a cheap-ass (read DIY/frugal) and your tie-rods are still in good shape, you can chop 29mm off the ends and re-thread them with an M15x1.5 Die.
Post  bluehellfire666 on Sun Apr 25, 2010 6:46 pm
so what is does that mean exactly? can i put on early control arms and tie rods, as well as struts and keep the late offset spindles? or is the offset really determined by the spindle?
bluehellfire666
Post  Admin on Sun Apr 25, 2010 8:09 pm
Early models have a different spindle than the late models. Which as Xschop said has a different bearing size and hub set up.
